Greetings EEVBees:
--I want to thank everyone for the good advice. For reasons of expense, trouble, and general laziness, I am going to go with Grenert on this one and use the $0.71 Panasonics. If she blow, she blows. It is a March 2007 Truetech 2-IN-1 17" LCD TV + DVD Model No. PVS31170S1, from the dumpster, so I do not want to risk too much on it.
--Indeed Conrad Hoffman is correct that the caps are from a SPS. There was a cluster of three 680 UF Caps (2 @ 25V and 1 @ 16V) within 1/4" of the Power Transistor and heatsink. The board was discolored from the heat of the caps. I assume that the heat from the Power Transistor caused the water in the electrolyte to evaporate, then the ESR started going up, and Bobs your uncle. Since there is room on the board, I plan to sleeve the leads and keep them at least 1" from the heat source.
--Retiredcaps appears to be correct in his identification of the company. If this were a more prime unit, or if I was sure of its condition, I might go to the trouble of hunting down exact replacements, but it is very easy to just use my DigiKey account, cheap and fast.
--With regard to the most excellent suggestions by NiHaoMike, I fear they are beyond the scope of this humble project at present. That, and I am not smart enough to know where to cut in additional capacitors. Would the additional caps happen to be in series or parallel with the 680 UFs, by chance? There is no room for a fan without bodging and dodging. But I much appreciate the advice, and will keep it in mind, and refer back to this post, if I need it again.
--Believe it or not, Amazon is still selling the babies for $169 US. But eBay just sold one for $78, shipping included.
"I'm all in favor of the democratic principle that one idiot is as good as one genius, but I draw the line when someone takes the next step and concludes that two idiots are better than one genius."
Leo Szilard 1898 - 1964
Best Regards
Clear Ether
