Okay, trying to be frugal, I went and bought some solder wick off of aliexpress, I got it, for fairly cheap.. 20 1.5m lengths (so that's 30 meters worth) for 8ish USD, when a local place charges nearly double that for some "Chem-Wik Rosin" soldering braid.
I go to use it tonight, and find out, it doesn't suck up the solder worth a crap! (Luckily-ish I had bought some more Chem-Wik a bit before I bought this cheapo-variety on aliexpress)
Now I go looking online and it seems some solder-wick is rosin/fluxless so could it be that the solder-braid that I got for a lark was/is fluxless?
Also, doing a bit of research on the variety Looking up online, I find out some info on the soldering braid I was using b'fore, (Chemtronics' Chem-Wik), there's two brand-names of the wick, Chem-Wik and Soder-Wick... are either one any better or worse for certain types of work?
Also, by looking up info on Chemtronics' website, it turns out I've been using the wick a bit wrongly (by dragging it across the boards vs just 'sopping' it up? Go figure.
But the type of solder-work I tend to use this stuff for is cleaning up bridged solder joints on thru-hole components, and salvaging old IC's from dead boards (I'm an 8-bitter o'er here so certain chips are valuable due to their non-being-made-anymore-ness) for use in various projects of mine.
Sorry about the rambly-ness of the post, but I figured I'd ask o'er here my plethora of somewhat related questions all-at-once vs spamming the boards with multiple tiny-tiny single-question threads.
