What do you consider strong antioxidants?
Mold is a real health concern, but "antioxidants" are absolutely tinfoil hat stuff.
Not true at all. Redox state of living cells can be the thing that determines their survival, and/or the integrity of their DNA, under a great many conditions.
n-acetylcysteine, alpha lipoic acid, are two very good ones, to start.
http://www.ncbi.nlm.nih.gov/pubmed/?term=n-acetylcysteine NAC- which turns into glutathione in the body- is good for 1000s of things, for example, it will protect your hearing!
Also, expectant mothers should take low doses of it daily, as glutathione is the way the body eliminates toxic stuff like mercury which can cause major problems with developing fetal cells. Glutathione is how our body naturally eliminates a great deal of junk out of the body in a gentle manner-
One very good example is described at
http://www.ncbi.nlm.nih.gov/pubmed/17298174 (a very important paper in its implications - which was never given the attention it deserved because of its easily forgotten name.)
ALA is another antioxidant, this time its one the body manufactures itself but in small amounts.
http://www.ncbi.nlm.nih.gov/pubmed/?term=alpha-lipoic+acid (again, supplementing it is good for a great many things, one of the best values in terms of bang per buck.)
There are multiple kinds of mold contamination and multiple ways they hurt people. Spores are not the means by which many people get sick, but they are important to the immunosuppressed, also the body must use up a single macrophage cell and some NO - again, both finite resources it needs, with each spore or fungal fragment it eliminates, an ability which declines over time.
(viable) spores can cause fungal invasion of the body in immuno-suppressed people. For most of history it was uncommon, because the immune system was usually capable of fighting it off. however, today, because of managed care, many doctors to save time, don't even bother trying to find out what disease a patient has (differential diagnosis - which they now denigrate as defensive medicine), instead they "manage" it by suppressing its symptoms with expensive drugs. Oftentimes, this is not a good idea because it leaves people wide open to fungal infection, which is extremely dangerous. The number of people taking these drugs is growing, and that makes it dangerous for there to be mold in the environment- but there is always some mold in the environment outdoors. Lining near composting facilities is not that uncommon and there there is a huge amount of mod, concentrated. That also releases mercury into the air as plants are composted which is a process that breaks them down and also generates heat. Mercury vapor is then absorbed by all living hings, including plants and people, and it builds up. Again, mercury exposure uses up the body's glutathione, which is the main system your body uses to break down xenobiotics (man made chemicals of all kinds) To improve your body's glutathione status, people (everybody) should take a modest dose of n-acetylcysteine daily, if possible.
the other kinds of mold exposure are
fungal fragments (see above re: using up resources) and carried on those fragments, increasing in amount as they get smaller and more respirable, is the worst exposure from molds, tiny particles which can be composed of poly-saccharides which contain literally thousands of mycotoxins which are chemicals, often incredibly strong poisons (i.e.
anti-biotics which are chemicals molds evolved over millions of years to kill other fungi-and other living things get killed as well, in varying amounts) We, "animalia" being closer to fungi evolutionarily than we are to other living things, are often collateral damage.
Molds are basically chemical factories. That property of them is increasingly being used in industry..
But, there is just no way to describe the incredible variety of poisons and other biologically active substances mold makes under conditions of high humidity. Typically to kill other molds . Generally the more humidity, the more mycotoxins in an exponential curve as you get more humidity. This is a really huge problem with food storage. A very large amount of food is spoiled in this manner and then must be diluted with clean food until it is legal to sell for human or animal feeds. The greatest danger posed by extreme weather throughout history has and is the problem of food spoilage and resultant mycotoxin created illness, cancers, etc. This was responsible for the period of witch burnings in Europe, for example. (due to grains production of ergot-alkaloids, which cause serious problems with circulation (i.e gangrene, miscarriages, and of course, the classic hallucinatory states which left those who ate contaminated grains with the feeling that they had been possessed by demons) A number of Aspergilli spp. also produce ergot alkaloids which can be produced in large quantities- pharmacologically relevant amounts in composting operations and also in moldy buildings. For example, mold growing on latex paint and shower curtains.
Among the worst mycotoxins - are the ones that cause living cells to rapidly die. An example is so called "toxic black mold" stachybotrys chartarum - which produces Trichothecenes - which are among the most toxic substances known to mankind.
Some persist in the environment indefinitely - they are stable and don't just go away.
They can build up in an environment that is subjected to periods of high moisture and humidity and then dry out, Mediterranean climates like California and Australia, for example where there is a rainy and dry season are the condition that will cause a buildup of trichothecenes to really high levels inside of closed paper faced gypsum wallboard cavities.. Older buildings that have seen repeated water damage can hold a lot of problems inside closed wall cavities where mold grew at one time and was never cleaned out.
If you are ever in a flood, when the water recedes, go around with a sledgehammer or hole saw and cut at least one, preferably two air holes in each stud cavity - every single one, to prevent 99% RH from developing in there - that is what causes the real mold nightmares. never ever let that situation just get painted over! Then get space heaters - the kind that blow and dry it out fast.
The worst mycotoxins are the trichothecenes, which are protein inhibitors and cytotoxic (they cause cells, especially newly growing cells to die) There are thousands of known ones and according to one scientist "we keep discovering new ones all the time".
How to get rid of them from the body?
A number of these toxins are quite gradually removed from the bloodstream by the liver and then they briefly end up in the bile, where they usually are re-absorbed in the gut - along with the low molecular weight poisons- and stay in the body for months or even longer. The way to get rid of them is to get rid of the bile by binding it with something irreversibly so it will be excreted in feces instead of being recycled.
Cholestyramine does that and as I said, its useful for that reason.
It and strong antioxidants are your first line of defense in a general manner for these ugly substances and they will also help with many others as well.
See
http://www.ncbi.nlm.nih.gov/pubmed/22253638 and the linked related papers
SO- to remove the toxic film from electronics you will need to be able to wash them with something that will dissolve away the mycotocins and then wash that away with clean water in a way which does not involve your needing to touch it.
Use thick rubber gloves or several layers of disposable rubber gloves. never re-use the gloves and turn off your cell phone so you wont be tempted to try to answer it while doing this.
Talk to an expert as to what solvents are best- be aware fumes may also be dangerous! and be aware that drying solvents will concentrate whatever is there so rinse it away down the drain, don't leave it to dry on the items. Given the trouble, you need to decide if it is worth it on an item by item basis.
If you are in a high mold environment you may not notice for a long time, you will just get progressively sicker and not know why. A clue is that your skin may become really dry. You may ache all over and not have any energy at all. the list goes on and on. Most of it is inflammatory phenomena.
A great amount of disease that people think is part of aging is actually caused by mold. A building that creates this illness needs to be gutted down to the studs, dry ice blasted and rebuilt. It wont be fixable by cosmetic changes. Move!
One thing that may help a lot are phytonutrients (they reduce inflammation dramatically) reseveratrol, curcumin, quercetin. What the mold does is it prevents your body from repairing things as it would normally and it prevents protein synthesis, it also depletes glutathione and causes an inflammatory cascade in multiple systems in the body. It also uses up the body's finite repair capacity. There is a so called Hayflick Limit on cell division. Mold toxins store up in fat cells and can and do persist in your body for years after a high exposure situation.
Older electronics equipment that contains CRTs should probably be superficially cleaned carefully if they have been in a really moldy place.
Sunshine helps, intentional exposure to sunshine (high levels of UV light) will reduce moldy belongings ability to make people sick a bit -to a lot. (not the worst kinds of molds but many of the not so bad kinds, the kinds most people encounter in a moldy home, the worst kind, stachybotrys is a sign of extreme humidity for a prolonged period. Even a small amount is a sign of a potentially large problem. It doesn't sporulate unless it is dying so you wont see it in spore trap testing.)
There is also a very expensive soap, Vulpex soap which is good for cleaning artwork and valuable papers and the kinds of clothing that one absolutely cannot part with. I have expensive fleece clothing which cost a lot and I was unwilling to part with which is mostly okay but every once in a while I still smell it, and its been washed at least 20+ times.
If ionizers or high voltages are involved or perhaps even if you live near the seashore (negative ions) AND there is a lot of mold in a building, electronics is much more likely to accumulate a lot of this greasy mold film which is incredibly persistent and very bad for you- as i said it literally goes through the skin right into the bloodstream.
Don't underestimate their ability to cause human illnesses. That said its possible to clean a lot of things if you take care to do it properly.
Also, there are MVOCs, another problem. Both from aerobic (less bad) and anaerobic (really nasty and contain known carcinogens) decomposition.
This is a paper on cleaning moldy posessions. the authors have done a lot of other work on this too so you may want to look at that as well. Especially Drs Strauss and Wilson.
http://www.ncbi.nlm.nih.gov/pubmed/15238314 >> Also click the authors names to search on several of authors of this paper. They were part of a team in Texas that studied mold and produced a lot of really important work until they lost their funding.
Wilson SC (Australian and really nice guy), Brasel TL, Martin JM, Wu C, Andriychuk LA (also really great person), Karunasena E, and especially Straus DC (one of the most knowledgeable scientists on molds and mycotoxins) . Click on their names on PubMed and you will find a lot of useful info.
We bought some testing from them and it turned out to be so bad they continued to do more testing for free, which was the thing that convinced us that we needed to go and not try to battle it out.
We should have left much sooner but we knew that it would mean having to leave a lot of good friends behind in an area we could no longer afford to live in - so it was a hard decision to make.
