Hi Dan, thanks for the reply.
Basically, I'm a network engineer. I understand how 802.11 works from OSI layers 2 and up. I do have a fairly good understanding of how RF works, limitations in terms of 2.4 and 5 GHz bands, channel widths, designing a channel plan etc...
But I'm stuck between a rock and a hard place. I basically need to show a room of non-technical people that if I take a measurement, say I use my phone and it measures -50dBm in a particular area relative to a particular access point, then it's a pretty darn good signal. On the flip side, -90dBm is a fairly average-to-bad one and something needs to be done about it.
How do I quantify it? I'm thinking worst case here... let's just say that room of non-technical people don't trust the figures I've provided and wanted to get someone to repeat my tests and verify what I've said as being true, how would I go about ensuring my tests are transparent and repeatable? Obviously not everyone is going to get exactly the same results as me, but it will be fairly close.
But say I measure -90dBm and someone else gets -85dBm, well that's "five better" than I got so I must be wrong.
It's actually a really difficult question I'm asking because the science doesn't translate well to laypersons.
