Sample Theta (contents to air) Deg C/Watt
Ceramic cup 4.1
Plastic insulated 4.6
Vacuum cup 1 26.7
Vacuum cup 2 10.5
Made one more measurement, on a proper 1 liter Stanley brand stainless steel vacuum coffee bottle (What is called a Thermos bottle in the US, whoever makes it. Sorry trademark lawyers.)
The much longer thermal time constant made some noise in my measurement system impossible to ignore so I change a bit about the measurement system and a bit more in the data reduction approach. Resulted in minor changes to the previous results.
Sample Theta (contents to air) (Deg C/Watt) Time constant (Minutes) Capacity (liters)Ceramic cup 3.7 89 0.36
Plastic insulated 4.8 204 0.63
Vacuum cup 1 29.4 1013 0.51
Vacuum cup 2 10.5 269 0.38
Thermos bottle 64.5 4486 1.03
The time constant is the real measure of how long things will stay hot, and it is obvious that size matters. The more it holds the more energy it stores.
The attached graph makes all of these visual. Here in the US 85 C is about as hot as anyone serves a hot beverage, legal liability goes through the roof at higher temps. Some may served be as much as 25 C cooler than this. Most sources say you can't drink anything much over 45 C, though you can sip much hotter liquids. Consumer testing has shown that people like their beverages to be served at 60C, apparently enjoying the sipping phase before it cools enough to drink. Lower limit on usable temp is personal taste, but some say it stops at 40C. Very narrow window to hit.
In any case the Thermos bottle can easily keep the stuff hot enough to require sipping for a very long working day. Don't know if a glass dewar would do any better, or if better performance would be useful.
