I have a very nice Intel "Skull Canyon" NUC that I use as a portable Linux workstation, mostly at my daughter's house where the power is somewhat unreliable. So, I replaced the UPS on my home network equipment and took the old (it could be > 10 years old) UPS to my daughter's house and placed it next to a laser printer. Apparently I had not printed anything since doing that until yesterday. Spooling a job to the printer caused the UPS to beep and the battery backed outlets to drop out very briefly, but long enough for the NUC to turn off.
The first time I did not understand what had happened, so I did it again with the same results. Moving the UPS a couple of feet away solved the problem, of course. At some point I will bring a scope and appropriate probes to see what I can observe. I'll at least be able to determine how long the AC drops out, maybe I will be able to observe a magnetic pulse as the laser printer fires up.
For the record, it's a Brother HL-L2380DW printer and an APC Back-UPS LS 700. UPS was on the right hand side of the printer.
