I just happened to make the mistake of listening to Electronic Design's Engineering Radio episode 16.
WTF? It was the first time I listened to Engineering Radio, and it will be the last.
One guy is reading what appears to be an an endless stream of scripted advertising. He is reading totally unenthusiastic (OK I wouldn't be enthusiastic if I had that job) with almost zero modulation of the voice. And that for more than half an hour. Couldn't they at least hire a trained professional radio host, and maybe motivate him with whatever it takes to motivate him?
If you are in desperate need for a drinking game, listen to it for the first 15 minutes, and have a stiff one every time the word "transparent" is used during the almost endless transparent LCD advertising.
To add insult to injury at the end the flash player is thrown into some kind of endless loop, repeating DigiKey advertising until your ears bled. In the end I had to close the browser to shut the stupid thing up.
If you want to listen to the train wreck yourself, e.g. if you ran out of sleeping pills
http://electronicdesign.com/blogs/engineeringradio.aspx
