Author Topic: Embedded C Book Recommendation  (Read 18855 times)
Offline Otatiaro
Re: Embedded C Book Recommendation
« Reply #50 on: February 17, 2013, 07:40:52 pm »
Hello,
For task switching I always go for the swap stack pointer and return approach.
Well, guess what is in the stack ?
To change tasks you just manipulates pointers (even if they are code pointers so kind of functors), but when you start a task, you most proably need to use the functor (the first address you'll put in the stack to branch to it on interrupt return).
Thomas.
