I think another problem with the test is that they use the same amount of water when determining efficiency. The big kettle is approximately half full, the volume of water is therefore sphere-ish and thermal losses will be smaller. In the case of the small kettle it will be full and the volume of water will be more elongated, thus it will have larger surface area to total volume and emissions will be larger. There will also be differences in convection currents in the water and so on.
I don't really understand why they expected much of a difference in efficiency?
Dosen't affect us. Here in 'straaalia we use wood powered kettles
You'll be a long time waiting till your billy boiled. We use electric 3Kw kettles in this part of the world.
I like my 3 kW kettle as well
but you can get huge power with a wood stove, efficiency and emissions are horrible though.
However, reducing the power input will always increase the amount of heat lost and reduce the efficiency, as more heat is being released into the surroundings, as you're waiting for the kettle to boil. This is basic physics.
This just proves the EU bureaucrats know nothing about science and engineering and the fact they're making laws which would increase carbon emissions and reduce efficiency of a kettle is a joke.
Well, it's not a law is it, it's allegedly something that has been proposed and we don't even have any details of what has been suggested so all this is just loose speculation.
If you look at all the bills in your local parliament I'm sure you would have nightmares for a week as well.
