Author Topic: Fake Panasonic caps?  (Read 3714 times)
Offline electrotwelveTopic starter
  • Country: in
« on: August 11, 2018, 12:00:54 pm »
I bought a bunch of Panasonic capacitors from RS Components and this is what came. I haven't opened the bag yet but none of the caps has  Panasonic printed on them on them. Are these fake? Part # is ECA1HM101.
Offline precaud
    • LinearZ
Re: Fake Panasonic caps?
« Reply #1 on: August 11, 2018, 12:30:57 pm »
The caps have Matsushita's logo on them. Matsushita Electric is the former name of the company, Panasonic was one of its brands.
So I'd guess they are probably not fake, but are quite likely old stock; the name changed to Panasonic about a decade ago.
  • Country: in
« Reply #2 on: August 11, 2018, 12:59:02 pm »
Should I return them?
Offline bob225
« Reply #3 on: August 11, 2018, 01:56:03 pm »
There not old stock or fake there just branded Matsushita aka Matsushita Electric Industrial  (MEI) with the M logo as are many of other Panasonic caps
You can find them world wide from all sorts of suppliers just put ECA1HM101 into google or Panasonic capacitor logo
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #4 on: August 11, 2018, 02:06:26 pm »
Exactly. The M is for Matsushita and at first glance they look the real deal.
One detail I find somewhat strange: they came in loose in a bag and not in cut tape - did you buy a bag or did you buy per unit just like any other part?
Offline helius
« Reply #5 on: August 11, 2018, 02:11:26 pm »
Through-hole capacitors are most commonly available in bulk packaging as pictured. The alternative as "ammo pack" style on paper tape; reels are obviously not an option.
Offline bob225
« Reply #6 on: August 11, 2018, 03:09:51 pm »
Places like RS, Mouser and Farnell give you the option of tape, reel (depends on the component), bagged, or singular packaging (for smaller quantities)
Offline rsjsouza
  • Eternally curious
« Reply #7 on: August 11, 2018, 04:28:30 pm »
I wasn't aware of the bulk packaging; thanks.
However, the type of through hole parts with paper tape can also be called reel.
Offline bob225
« Reply #8 on: August 11, 2018, 04:52:03 pm »
The tape/card usualy comes in a concertina format that come out of a box (larger components)
Offline rsjsouza
  • Eternally curious
« Reply #9 on: August 11, 2018, 05:05:18 pm »
I am not talking out of thin air; I have received through hole capacitors in a reel lots of times.
What I have seen before is resistors coming on a concertina shape, (but I am not saying capacitors can't come this way as well).
Offline bodger
« Reply #10 on: August 11, 2018, 05:11:51 pm »
I've got a bunch of Panasonic FR series caps, they have no branding on them, not even the 'M' for Matsushita. As far as I'm aware quite a few Panasonic capacitors are not branded, they just have the series name printed on them.
Online rdl
« Reply #11 on: August 11, 2018, 06:39:19 pm »
I also have a bunch of Panasonic FR series bought several years ago from Mouser that have no branding.
The following users thanked this post: bodger
Offline scuzzyTerminator
« Reply #12 on: August 11, 2018, 06:48:41 pm »
If they are not reel they must be faek.
Sorry.
Offline NiHaoMike
    • Facebook Page
« Reply #13 on: August 11, 2018, 07:18:38 pm »
How are they normally installed on PCBs in a high volume production environment? Manually, complete with the occasional bang when an assembler makes a mistake?
Offline rsjsouza
  • Eternally curious
« Reply #14 on: August 11, 2018, 07:43:57 pm »
Sorry.
Not necessarily. I have seen through hole capacitors in wafer (concertina) supply as well. After helius posted, I looked at Mouser, Vishay and others and confirmed they can have bulk, reel and wafer packaging.
Online rdl
« Reply #15 on: August 11, 2018, 08:30:25 pm »
I just looked and I have a few very old Panasonic TSW series large electrolytics bought from Digikey around 1990 or earlier (a few still in Digikey labelled bags). Some have the Matsushita "M" and a few have a stylized triangle logo, but none of them have any brand name on them.
Offline c.coyle
« Reply #16 on: August 11, 2018, 08:46:00 pm »
If you see a capacitor actually marked "Panasonic", you should be suspicious.
The following users thanked this post: amyk
Offline helius
« Reply #17 on: August 12, 2018, 12:41:02 am »
My understanding is that bulk packaging is indeed mostly used by manual assembly operations. Manual assembly is still widespread in two segments: some high profit margin goods in specialized markets; and low-tech items assembled as piecework in developing countries. The factor common to both is that the volume of goods assembled in each facility is too low to support the capex of automation.
There is potentially a third story for bulk packaged components, if flexible robots continue to increase in capabilities.
Offline mariush
« Reply #18 on: August 12, 2018, 01:00:50 am »
Yeah, Panasonic sells electrolytic capacitors in bulk packaging.
They also sell some series of capacitors without any branding whatsoever, for example the FR series. You know they're Panasonic by the vent shape and by buying them from a reputable distributor...
The M logo is not the code for tolerance (+/-20%), it's the Matsushita logo like others said... though I have to say usually the "legs" of the M are slightly more curved normally. Maybe it's a limitation of the printing process, or the logo is changed to fit in smaller vertical height  considering the small diameter of these capacitors... I don't know.
Anyway, unlikely to be fake... not sure who would fake 85c rated capacitors when they can fake more expensive low esr 105c capacitors...
ps. bulk capacitors can be easily used in assembly lines where you have 10-20+ persons each with one job, like placing an inductor, placing 3 capacitors, placing a heatsink etc etc ... no sense to use lead tapes and whatnot, it would only slow down the process.
See for example from around 5:20  .. even Gigabyte used to make motherboards around 2012 by placing some components manually:
« Last Edit: August 12, 2018, 01:06:37 am by mariush »
