Author Topic: Fibreglass pencils  (Read 7381 times)
Offline img
Fibreglass pencils
« on: July 27, 2011, 06:54:48 pm »
While eBay-crawling in search of some Stannol solder to try, I saw something called a fibreglass pencil. Apparently it's to be used to clean tracks and contacts.
Hmm... but doesn't it scratch these tracks and contacts? If you used this 'pencil', can you please share the experience?
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Fibreglass pencils
« Reply #1 on: July 27, 2011, 11:07:58 pm »
They work pretty well for cleaning really dirty boards or removing solder resist however you end up with loads of fibreglass bits which irritate the skin like hell.
Wire brushes are nealy as effective without the nasty debris.
Day Job: Mostly LEDs
Offline david77
« Reply #2 on: July 27, 2011, 11:59:55 pm »
Very usefull to clean corroded contacts & such, also works well to remove permanent marker and dirt of all descriptions. I always keep one in the workshop.
Offline Fraser
« Reply #3 on: July 28, 2011, 03:43:30 am »
I wouldn't be without one.
They are abrasive (they have to be to work) but plating damage is minimal.
When using such a glass fire pencil I advise the wearing of latex (or whatever you prefer) gloves and working on a disposable surface such as  a newspaper. Once you've completed the job, shake the debris out onto the paper, then bin it carefully. It is important to not get the tiny glass fibres (that are shed during cleaning) into your skin as has already been stated. If such occurs you will suffer very irritating itching of the site for days and it probably isn't a great health idea either. You may wish to wear a dust mask as well, though I have never found this to be needed.
In a sentence.... a great tool to have on hand but handle with suitable care to avoid unpleasantness afterwards !
« Last Edit: July 28, 2011, 04:52:34 am by Aurora »
Offline img
« Reply #4 on: July 28, 2011, 04:51:38 am »
Thank you for the advice.
Call me stupid, but I just finished cleaning liquid damage to a Mac mini board, and I am having a hard time imagining how this fibreglass pencil with 4mm tip is even going to work on this board; 4mm looks huge next to tiny clearances on this densely packed board.
Is it possible to get different size tips, or there is pretty much only 1 size?
Offline Fraser
« Reply #5 on: July 28, 2011, 05:00:00 am »
STOP !
Please explain exactly what is on the board and what you are trying to clean.
I would not normally be using a FG pencil on a PC or MAC PCB. Fluid damage can be a killer as the worst damage often occurs under the IC's where it's very hard to examine or clean. Many fluid damaged PCBs can be soaked in warm distilled water or IPA to remove conductive contaminants. If rust has formed it is very bad news for the PCB. Any BIOS memory battery will be US, and any +ve tracks or IC pins connected to it will corrode heavily due to electrolytic action.
Please let us know the full story so that we can best advise you  :)
Offline img
« Reply #6 on: July 28, 2011, 05:14:48 am »
Well, while what you are saying is true, in the past 10 years I brought back a fair number of liquid-damaged boards, assuming the damage occurred fairly recently and no major damage was done to components (and the customer is very lucky). My question isn't about how to clear liquid damage, really.
I am trying to understand the intended application of these fibreglass pencils which I have never seen in person, I just saw one for the first time in my life on eBay.
So you're saying that the pencil is of no use to me because I mainly rework and repair mobile phones, laptops, and such?
Online IanB
« Reply #7 on: July 28, 2011, 05:29:33 am »
I have a fibreglass pencil that I picked up either at Radio Shack or Fry's (I don't remember which). It is like a felt tip pen with a thick fibreglass tip and a screw advance mechanism like on a glue stick. It works well for cleaning the oxide film from the surface of copper or other metal surfaces making it nice and shiny again without excessive abrasion. You just rub it gently on the surface to be cleaned until it is bright and ready for soldering.
I have not noticed the fibreglass bits problem that Mike mentioned; maybe this depends on the particular make of pencil?
Offline img
« Reply #8 on: July 28, 2011, 05:35:17 am »
Do these pencils come only in 1 size?
Offline Bored@Work
« Reply #9 on: July 28, 2011, 05:42:14 am »
They are sort of like tiny wire brushes. The fibers are much smaller than wires in a wire brush but still very hard. The tiny fibers give you finer control over the applied force to the surface, compared to a wire brush. And that allows not just to scrap hard stuff from a surface, but also to polish the surface to some extend.
Online IanB
« Reply #10 on: July 28, 2011, 05:43:17 am »
I've only ever seen one size. It's about the same size as a flux pen.
Offline img
« Reply #11 on: July 28, 2011, 05:45:40 am »
Probably I should get one of these and have some quality time with it and a dead board, see how it feels and what it does and go from there.
Thanks very much for your replies and advice.
Online IanB
« Reply #12 on: July 28, 2011, 05:50:29 am »
I've found the best technique for using one is to keep the "brush" short and use a light touch. Don't force it, just let the abrasive tip do the work. They are good for fine control and small areas.
Offline img
« Reply #13 on: July 28, 2011, 05:54:37 am »
That's useful, thanks.
You mean you just 'sharpen' the pencil to suit the type of area you're working on?
If so, what do you sharpen it with?
How short do you recommend to keep the brush?
Online IanB
« Reply #14 on: July 28, 2011, 06:13:35 am »
No, you don't sharpen it. Think more of a mechanism like a glue stick (a "Pritt Stick"). The brush advances out of a metal tube and as the end wears down you just advance it a bit more. You end up with a circular brush a few mm in diameter. You hold the pen vertical when you use it so the end of the brush is flat against the surface.
Online IanB
« Reply #15 on: July 28, 2011, 05:58:39 pm »
A product picture:
