The same car in the US does more or less mpg than in the UK? And in Australia?
A British gallon is significantly bigger, so of course a car does more miles per British gallon. The measures in British motoring are really silly, though. We buy fuel in litres, and burn it in miles per gallon. If your car's systems display the actual content of the fuel tank it will display this in litres, while the same computer shows your efficiency in miles per gallon.
If you think that is silly, go flying here in Canada
Airplanes burn (US) Gal/Hr;
which weigh 6lb/gal - you care about the weight
But you buy fuel in litres
You fly in hundreds of feet
You set your Altimeter in inches of Hg
Direction is in degrees magnetic for some things, degrees true for others
As for weather reports (a Canadian and British example)
METAR CYYJ 022200Z 29006KT 20SM FEW020 BKN170 OVC240 04/02 A3032 RMK SC1AC6CI2 SC TR SLP269=
METAR EGLL 022220Z AUTO 21017G27KT 5000 -RA BKN009 BKN017 OVC026TCU 12/11 Q0990 TEMPO 3000 +RA BKN008
CYYJ = ICAO code for Airport (which can be very different than the 3 letter IATA code)
022200Z = date/time in UTC
29006KT= wind speed /direction (06 Kts @ 290 degrees true)
20SM = visability 20 statute miles
FEW020 = few clouds (1/10) at 2000ft
BKN170 = broken clouds (6/10th) at 17000ft
OVC240 = overcast at 24000ft
04/02 = temp 04, dewpoint 02 (deg C)
A3032 = Altimeter 30.32" Hg
Of course note the differences in different countries, At Heathrow (EGLL / LHR) with altimeter 990 hPa (Q0990) instead of "Hg, and visibility in metres (9999) not Statue Miles.
For added fun and excitement, when you call the airport for a wind check, you get the results in degrees magnetic (which is also how runways are numbered - divide bearing by 10)
It's amazing that incidents like ACA143 don't happen more often (fuel loaded in lbs, entered into computer as Kg, ran out halfway there)
