Quote from: coppice on January 02, 2018, 12:16:11 amQuote from: GeorgeOfTheJungle on January 01, 2018, 11:34:23 pmThe same car in the US does more or less mpg than in the UK? And in Australia?A British gallon is significantly bigger, so of course a car does more miles per British gallon. The measures in British motoring are really silly, though. We buy fuel in litres, and burn it in miles per gallon. If your car's systems display the actual content of the fuel tank it will display this in litres, while the same computer shows your efficiency in miles per gallon.If you think that is silly, go flying here in CanadaAirplanes burn (US) Gal/Hr; which weigh 6lb/gal - you care about the weightBut you buy fuel in litresYou fly in hundreds of feetYou set your Altimeter in inches of HgDirection is in degrees magnetic for some things, degrees true for othersAs for weather reports (a Canadian and British example)METAR CYYJ 022200Z 29006KT 20SM FEW020 BKN170 OVC240 04/02 A3032 RMK SC1AC6CI2 SC TR SLP269= METAR EGLL 022220Z AUTO 21017G27KT 5000 -RA BKN009 BKN017 OVC026TCU 12/11 Q0990 TEMPO 3000 +RA BKN008CYYJ = ICAO code for Airport (which can be very different than the 3 letter IATA code)022200Z = date/time in UTC29006KT= wind speed /direction (06 Kts @ 290 degrees true)20SM = visability 20 statute milesFEW020 = few clouds (1/10) at 2000ftBKN170 = broken clouds (6/10th) at 17000ftOVC240 = overcast at 24000ft04/02 = temp 04, dewpoint 02 (deg C)A3032 = Altimeter 30.32" HgOf course note the differences in different countries, At Heathrow (EGLL / LHR) with altimeter 990 hPa (Q0990) instead of "Hg, and visibility in metres (9999) not Statue Miles.For added fun and excitement, when you call the airport for a wind check, you get the results in degrees magnetic (which is also how runways are numbered - divide bearing by 10)It's amazing that incidents like ACA143 don't happen more often (fuel loaded in lbs, entered into computer as Kg, ran out halfway there)
And don't forget the standard temperature lapse rate of 2 degrees C per thousand feet of altitude-Pat
Quote from: HighVoltage on January 03, 2018, 01:34:49 pmMay be one day we will have a worldwide English dictionary that everyone would agree on to use.Samuel Langhorne Clemens already had a plan for that. For example, in Year 1 that useless letter "c" would be dropped to be replased either by "k" or "s", and likewise "x" would no longer be part of the alphabet. The only kase in which "c" would be retained would be the "ch" formation, which will be dealt with later. Year 2 might reform "w" spelling, so that "which" and "one" would take the same konsonant, wile Year 3 might well abolish "y" replasing it with "i" and Iear 4 might fiks the "g/j" anomali wonse and for all.Jenerally, then, the improvement would kontinue iear bai iear with Iear 5 doing awai with useless double konsonants, and Iears 6-12 or so modifaiing vowlz and the rimeining voist and unvoist konsonants. Bai Iear 15 or sou, it wud fainali bi posibl tu meik ius ov thi ridandant letez "c", "y" and "x" -- bai now jast a memori in the maindz ov ould doderez -- tu riplais "ch", "sh", and "th" rispektivli.Fainali, xen, aafte sam 20 iers ov orxogrefkl riform, wi wud hev a lojikl, kohirnt speling in ius xrewawt xe Ingliy-spiking werld.
Quote from: glarsson on January 03, 2018, 04:37:11 pmQuote from: HighVoltage on January 03, 2018, 01:34:49 pmMay be one day we will have a worldwide English dictionary that everyone would agree on to use.Samuel Langhorne Clemens already had a plan for that. For example, in Year 1 that useless letter "c" would be dropped to be replased either by "k" or "s", and likewise "x" would no longer be part of the alphabet. The only kase in which "c" would be retained would be the "ch" formation, which will be dealt with later. Year 2 might reform "w" spelling, so that "which" and "one" would take the same konsonant, wile Year 3 might well abolish "y" replasing it with "i" and Iear 4 might fiks the "g/j" anomali wonse and for all.Jenerally, then, the improvement would kontinue iear bai iear with Iear 5 doing awai with useless double konsonants, and Iears 6-12 or so modifaiing vowlz and the rimeining voist and unvoist konsonants. Bai Iear 15 or sou, it wud fainali bi posibl tu meik ius ov thi ridandant letez "c", "y" and "x" -- bai now jast a memori in the maindz ov ould doderez -- tu riplais "ch", "sh", and "th" rispektivli.Fainali, xen, aafte sam 20 iers ov orxogrefkl riform, wi wud hev a lojikl, kohirnt speling in ius xrewawt xe Ingliy-spiking werld.Aaaaaaaaaaaaarrrrrrrrrrrrrrrrrggggggggggggggg What did you do?I can no longer read english!!!It's going to take me a day to undo this!!!
