Author Topic: Warming up electronics after shipping in winter ?  (Read 351 times)
Offline lordvader88
« on: March 14, 2019, 05:45:27 pm »
When I've gotten things like motherboards and videocard's delivered in the winter at well below freezing, I've let the sit for a while to warm up and not have water condensing on them and hopefully not mechanically stress anything.
Anyone else cautious like that ? Should I do it with an LCD monitor too ?
Online Ranayna
Re: Warming up electronics after shipping in winter ?
« Reply #1 on: March 14, 2019, 06:19:29 pm »
Anything so cold that you can feel condensation even on the packaging will sit at home for at least a day.
Do not put it directly next to the heater ;)
Regarding fast temperature changes, a small anecdote: In the winter, when I open the window of my bedroom, where also the computer is located, I always hear sometimes really loud cracking sounds from my monitors. I usually open the window in the early morning, to get up better, so the computer is turned off.
After several years doing this, the sound still makes me wonder, but so far nothing broke.
Online med6753
« Reply #2 on: March 14, 2019, 11:08:06 pm »
Over this past winter I took delivery of a Siglent SDM3055 and a Fluke 8810A. Both of them were freezing cold from sitting in cold warehouses and delivery trucks. I let them sit for about an hour at room temperature before powering up. But even so it took a good 2 to 3 days of simply powered on idling before they really stabilized.
Online OwO
  • Country: cn
  • Hewwo, I'm Gabwiel from OwOComm!
« Reply #3 on: March 14, 2019, 11:31:01 pm »
Probably inconsequential compared to the thermal stress during reflow. The only thing I would be careful about is condensation. I would say it's fine to put it on top of the heater, warm it up, check for condensation, and power it on.
Hewwo, w-welcome to OwOComm headqwarters, yuw can call me Gabwiel! UwU It's abowt time I intrwoduce yuw to a-an exciting worrld ow commuwnication systwems!
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #4 on: March 14, 2019, 11:43:16 pm »
Not everything insde the assembly passes through reflow. Don't put it on a heater.
An engineer never has a problem. He just needs more time.
eBay shop with all the gear you need!
FS: Agilent Infinium 54815A, 54825A, R&S CMU 200, CRTU-G, SFU, SMIQ06L, HP8714B, THS720P, HP4192LF, Marconi 6201B 8GHz, Lecroy WP 960,950,
Online KJDS
    • my website holding page
« Reply #5 on: March 15, 2019, 06:14:47 am »
Caps on old IEC mains sockets with the built in filter were the most likely thing to suffer. Always stank when they blew
Offline Neilm
« Reply #6 on: March 15, 2019, 06:57:33 am »
If you are looking at test gear I would definately allow it to settle. I have seen units that spec 12 hours recovery after shipping before powering up. It does resolve to 100 atto-amps though.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Offline electromotive
« Reply #7 on: March 15, 2019, 07:07:36 am »
Due to breathing issues, I keep the humidity in my house somewhat high. I always let hardware acclimate to the house temperature and humidity before use. No less than 24 hours. More than that is overkill here in Ohio, USA.
