https://www.9news.com.au/national/2018/03/04/21/31/perth-girl-fighting-for-life-after-electric-shock-at-home"According to PerthNow, Ms Harrison had reported other power problems at the home in recent months including a “burning electrical smell” where an electrician was unable to find a cause."
"She claims she reported a problem with the electricity at the public housing property to the Department of Housing, about an hour before her daughter was shocked"
http://www.abc.net.au/news/2018-03-05/denishar-woods-remains-in-critical-condition-after-electric-sho/9510242"She said her organs reached 38 degrees Celsius and she was on a cooling pad in hospital to try to limit the damage."
"Ms Harrison she was out watering in the garden on Saturday night when the power to the house went out.
When she went to the meter box to turn the power back on, she received a small electric shock.
She said she contacted the Department of Housing emergency contact line to notify them of the fault, but she said no one warned her not to touch anything."
Someone in the Department of Housing (WA) NEEDS to go to jail for this shit.
All the warning signs were there that the house was live at mains voltage.
The power went out because the Neutral was completely disconnected due to a fault, possibly underground. When the running tap was touched the circuit was completed, earth on house (tap) to ground, to earth in street power cabling.
related stories
http://www.abc.net.au/news/2018-03-05/what-causes-taps-to-be-electrified/9508664What could have been done ?
1) Touch nothing on, in or attached to the house.
2) Switch off the main breaker, using an insulating material, like a length of timber, plastic rod etc.
3) Properly investigate the original complaints, months ago, and fix it before be became lethal.
4) Report a live meterbox to the power company, who will warn of the dangers and rush out to make it safe.
Here is hoping the girl and her mother are OK, longer term.
