Author Topic: How can I change the chinese UI to english UI of my Tekway DST 1062B?  (Read 2768 times)
Offline bibly
Hello,
I need to know how to change the UI from Chinese to English or if possible both languages selectable in the menu? Could anyone help me?
My scope is a DST1062B Tekway, Firmware 2.06.3(110225.0).
I tried to make a FW dump as explained here: http://www.eevblog.com/forum/index.php?topic=1571.msg53336#msg53336
But I am not sure that the scope did this dump. Remember, there message boxes are in Chinese only.  ???
Thanks.
Offline bibly
Re: How can I change the chinese UI to english UI of my Tekway DST 1062B?
« Reply #1 on: August 18, 2011, 06:26:09 am »
tinhead helped me to change the UI:
110225.0 is fine, then this is probably not the newest hw1007, so you can download this here
http://www.eevblog.com/forum/index.php?action=dlattach;topic=1571.0;attach=11334
which is fw 110531.1 for Tekway 1062B
and this here
http://www.eevblog.com/forum/index.php?action=dlattach;topic=1571.0;attach=11517
which is new english language file for that firmware
Offline tinhead
« Reply #2 on: August 18, 2011, 06:26:27 am »
now as you scope is english you can use this tool
http://www.eevblog.com/forum/index.php?topic=1571.msg35683#msg35683
to made a dump
Offline bibly
« Reply #3 on: August 18, 2011, 06:33:56 am »
Is it necessary to make a FW dump? The FW you gave me is saved on my pc.
Offline tinhead
« Reply #4 on: August 18, 2011, 06:48:40 am »
depends .. imagine the NAND flash is broken (which might happens), what you will do then ?
The firmware itself is only one executable, bunch of text files, but within he NAND flash is the whole Linux OS,
manufacturer device dri┬┤vers, additional manufacturer aplikations, the factory calibration (which match only your DSO),
the serial number informations and so on.
So did it make sense to have a backup of all these things? You decide ...
Offline bibly
« Reply #5 on: August 18, 2011, 07:17:31 am »
OK, I understand. I'll do this tomorrow.  ;)
Offline Mrbrillio
« Reply #6 on: September 23, 2011, 05:33:27 am »
Hi! I'm an electric engeneering student and a new member of this community.  :D
I have discovered this blog/forum some months ago and since then I have watched the Dave's videos and read a lot of topic in the forum.
As you can imagine I have just bought a Tekway DST1062B in China. The problem is that i don't know how to change the language from chinese to English.
I have read about all the topic for the 200MHz hack and I have tried alot to enable the English language but i haven't find the way.
Can you please suggest me how to do?
The firmware of my scope is 2.06.3(110225.0) that i think it's not exactly the last one :P.
Offline Mrbrillio
« Reply #7 on: September 24, 2011, 07:18:18 am »
I did it!  8)
At one point I thought I bricked it because it remained locked on reboot with RUN/STOP button on yellow.
Then it take it power off for some minutes and it restarted correctly
Now I have some problems with the firmware dump
With the specific DST1062 dump utility i obtain this result:
"Firmware update failed, error: 0xf7   Illegal update files detected"
With the universal dump utility i obtain this result:
"Firmware update failed, error: 0xfe   No upgrade files detected on USB device"
I will retry tomorrow....
Offline Mrbrillio
« Reply #8 on: September 25, 2011, 12:07:20 am »
No results  :'(
It continue to give me the same errors.
Someone have any idea how to do the dump (DST1062B 110531.1)?
