"Deadly" starts at 50mA and 60VAC can qualify for that.......
'Yellofriend'.... You are not quite right mate. Yes, people generally forget that it is not
the Voltage that kills you, but the Current ! Someone may have wet fingers, and be standing
on a wet floor in bare feet, in circuit with say 60/80/90 Volts and receive a lethal dose! through
the heart, resulting in uncorrected Ventricular fibrillation.
Someone else way be in a relatively 'dry' environment, and have very dry skin, and not be adversely
affected by 'brushing' their fingers or hand (hands) over 'those' voltages, or even 110-V (in the U.S.),
and/or in my case even 240-V (in Australia). Yes... we feel it !!!!!........
(NOTE: I've been an Industrial Electrician, and Special Class Technician for 40 years, and I know what
I am doing, and do NOT expect others to copy what is/was standard practice to me !).
(BACK to CURRENT for now...)
Generally these days, we have power switchboards that rely on either 'ELCBS', or 'RCDs'....
(Earth Leakage Circuit Breakers, and Residual Current Devices/Detectors).
VERY ROUGHLY, (and many types work in many ways!!!), they can detect an imbalance in the
current flow in the Active & Neutral, and 'surmise' that the 'extra' is flowing through YOU, if you
touch something 'live', and you are in some way or partially 'Earthed'.....
Now USUALLY these devices are set to 'Trip', between 25mA & 30mA, and can do so in a small
fraction of a second! AT THAT current, and above, you may be killed.... However, if you have
an isolating 'transformer', especially where neither output wires are 'REF'd' to Neutral/Earth, then
it may not protect you ! (This subject is too big to explain simply....... sigh....)
Then we can get into 'Auto-Transformers' where there is no elect isolation from Primary to Sec.
And the 'Centre-Tapped' Secondary windings which throw a whole 'nother curve ball......
Basically..... 36V should never be anything to worry about.....
B.T.W. Just for interest !!!!!
You have a BETTER chance of surviving an 8,000V or 10,000V shock, for 1 or 2 seconds, than
a 240v shock for say 3 to 5 seconds !!! Why?.....
Lower voltages can leave the heart in that state I mentioned, being "Ventricular Fibrillation".
This is a useless 'quivering' action by the heart, leading to death, without using a "Defibrillator" !
Very HIGH voltages, although leading to physical BURNS, (and subsequent death if prolonged),
initially cause the Heart to electro-muscularly clamp so tightly, that it can't get into that State !!
So when the 'shock' is removed, it basically goes back to normal !!!!!
(Survive but burnt
