And the panels are at an angle for higher efficiency, which also means that rain and snow will help clean them. If that's not enough, a service cart can drive down the path and mop them off.
They won't be driven on by tractor-trailers, or heavy road construction or maintenance equipment, or people with studded snow tires or tire chains.
They won't be scraped by snowplows.
They won't be scratched by gravel and sand grains under the tires of heavy vehicles.
Dripping oil, antifreeze, and transmission fluid won't cover them, seep into the surface scratches, and be impossible to remove.
They don't need a special material or pattern etched into the glass for traction, so they don't lose solar efficiency. Nor do they need to be replaced when the traction layer wears off.
When panels do need to be replaced, it can be done without closing lanes of the road or endangering service workers.
All this, available now without special engineering or development of magic materials or testing of new traction compounds or surfaces. Practical now, at a fraction of the cost of putting solar panels into the worst possible location imaginable short of a dark basement.
