The three remaining countries who still use ye olde imperial system are the three amigos: The USA, Liberia and the Myanmar. Maybe they should form a new trading bloc, called the blocheads .
There is no reason why anyone should still be laying out PCB's using imperial measurements, except as an excuse for being mentally challenged maybe.
Actually Myanmar is switching to Metric, there will only be two left.
https://en.wikipedia.org/wiki/Myanmar_units_of_measurement#Adoption_of_SI_.28Metric.29_SystemHere in Canada we have an interesting dilemma. So much of our commerce and systems are with the USA, that lots of imperial things remain, especially in industries like construction.
Pipe is still in inches (fractional inches)
Machine Screws are typically UNC (#8/32, #10/32, etc)
Houses are still built on 16" centres between studs.
Some things are even uniquely Canadian, like a most wood screws have a Robertson head.
but my favourite example is seeing plywood advertised in the store as: 4 foot by 8 foot by 19 mm
I'd love to see everything go Metric, but it's hard when there's so much out there that is imperial. How big are the tires on your car 205/60 R15. The 205 is mm , the R15 is inches. Now that's screwed up.
And don't even get me going about aviation where you have feet (altitude), metres(altitude in some places, visibility in some places), statute miles (visibility), nautical miles/hr (wind speed), degrees true (some wind direction), degrees magnetic (wind direction at airports, runways), pounds (weight of fuel), litres (what you buy your fuel in), gallons per hour (what you consume your fuel as) and so on...
It's amazing there aren't more accidents like Air Canada 143 where they loaded a plane with lbs instead of kgs of fuel.
