Author Topic: Inside the Tesla Roadster power inverter for 200kW motor  (Read 27632 times)
Offline Arlo1
Re: Inside the Tesla Roadster power inverter for 200kW motor
« Reply #25 on: February 28, 2014, 04:14:31 am »
great thread guys.
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #26 on: February 28, 2014, 08:53:36 am »
There are loads of devices with insulated tabs. First one I found with 10s of searching: https://www.fairchildsemi.com/ds/HG/HGTG30N60B3.pdf
Did you paste the wrong link by accident..?
Here's an example,
http://www.digikey.com/product-detail/en/IXGR48N60C3D1/IXGR48N60C3D1-ND/2117159
but it's a little more expensive (though the ratings aren't quite equal, either).
How come? There is no mention that the tab is connected to anything. In my experience that is the case then. For a counter example this has a clear marking that the tab/flange is not isolated: https://www.fairchildsemi.com/ds/FG/FGH75N60UF.pdf
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #27 on: February 28, 2014, 10:12:44 am »
Lack of information is not positive proof to the contrary of that information... ;)
It's doubly dangerous, because 1. it doesn't specify that the pad is connected (however, I would assume by default that it is, particularly because a standard TO-247 package is specified), and 2. if it IS isolated, the isolation standoff is not specified -- note in the IXYS 'ISOPLUS247' case, it's rated for 2500Vrms.  So even if it were isolated, you have absolutely nothing to rely on.
While you can make whatever hand-waving you wish (maybe even buy some and inspect or test them yourself), without #2, you are guaranteed nothing.  What's more, the manufacturer is free to change the part under that constraint (or the lack thereof) as they see fit.  (Though most datasheets include that nasty little phrase, "subject to change without notice", or something to that effect, making that kind of moot anyway...)
Seven Transistor Labs, LLC
Offline free_electron
    • SiliconValleyGarage
« Reply #28 on: February 28, 2014, 10:16:13 am »
Intrinsic silicon is not used as an insulator, never has been(?), and never will be.  It is impossible in general to use for that purpose.
You may want to update your sources.... We have a process on fully depleted silicon to make very low power (as in quiescent currents) devices. I don't know if this process is used to make power transistors. But it does use a layer if fully depleted silicon because of the electric isolation. FD-SOI fully depleted silicon on insulator. We already have a number of devices i. This process. So does intel and a vunch of others.
