I'm looking to but a good DMM now but there is ssooo much info in here and 'out there' that i don't know where to start.
You can start with Dave's
EEVblog #75 video for things to look for.
I have the budget
Fluke 17B China-only model (less than $100 US dollars delivered).
Pros/cons?*Continuity mode is fast but probably not as loud as I like it and is scratchy when the probes touch together.
*Diode testing range is poor, not the more favourable 4V (I don't know if I'll be testing LEDs with 3V drops...)
*Doesn't have Fluke's
Touch Hold feature (allows the meter to remember the reading after you take the probes off the subject); instead it has the 'lame'
HOLD button that you can only press while the probes are on the subject to freeze the reading. Silly.
*Doesn't have the claimed DC Volts accuracy the 87V has (along with other ranges), but really I don't need any more accuracy; it's more than I need for my uses and Fluke's electricians meters like the $200ish 117 have the same accuracy in many ranges (but accuracy is less important for an electrician's meter than for electronics, apparently).
*It runs on 2xAA rather than the unfavourable (to me) 9V battery that the 87V uses. I have heaps of rechargeable AAs when the internal batteries run out so I love this. I never want to have to buy a 9V battery again and rechargeables are harder to find.
*It doesn't have True RMS, something which I probably won't care about for years, if then.
*It doesn't have a backlight, but I don't find myself using the meter in the dark environments so that is fine with me.
*It doesn't have
MIN/MAX mode, so I won't be able to recall the minimum and the maximum readings when I'm finished reading.
*It has a thermocouple included for temperature readings and is useful for testing hotter components like heatsinks and so on, apparently.
*It is built very solidly, probably like the more expensive Flukes I've never used.
*Replacing the battery isn't the easiest taking that door off, and to replace fuses you have to take the whole back cover off (no fuse window for easy replacement access). I probably will never have to replace the fuse.
*It's a 4000-count meter but the DC volt accuracy is 0.5%, but according to Dave it needs to be 0.25% according to video #75. I still don't understand this properly. Regardless, I don't think much of accuracy specs.
These little omissions the 17B has over the 87V are well worth the $300 or so savings to me
Especially for my simple uses.
