Do people really use bulky irons like that for pcb work?
A bulky handle makes me think the tool is better suited to plumbing or stained glass, but I might be spoiled.
It doesn't look any bigger than a Weller WTCP.
There are still a lot of those being used for PCB use.
I find they are easier to manipulate than some of the more modern irons.
AND they have enough reserve to not wimp out on boards with large areas of copper.
In my last job, we had a cheapo rework station for the really small stuff & a Weller for everything else.
I often didn't bother to turn the other thing on, as the Weller was quite capable.
In the previous job, we had earlier versions of the Hakko.
These would often be unable to make satisfactory joints on boards with a lot of copper, unless we preheated the PCB with a heat gun.
Main problem was poorly designed boards & excessive diameter interconnecting wires, but that's another
story.
