I don't really have a "good" power supply...I have some cheap wallwarts that I can rig up with an LM317 and get the job done, but nothing dedicated, which becomes frustrating.
So I'm embarking on a mission...I'd like to build an L200 dual voltage power supply. I believe +/- ~15V will be sufficient. I am trying to keep cost at a minimum and quality high. I don't need tons of features, but I do want it to last a while. Blah blah blah
Okay, so I looked at the L200 designers guide and picked out the Fig. 21 design which is a positive/negative supply.
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/APPLICATION_NOTE/CD00003773.pdfI have a few questions because I can't really see the drawing too well. There is a dotted line between the positive section and the negative section of the power supply. It's labeled "tracking". Is that saying that the wipers of the voltage adjustment potentiometers are connected to eachother? I don't really know what the term "tracking" means...
Also, can I simultaneously control current by putting a potentiometer between pins 5 and 2? Or will the output voltage be affected? ( I don't think it should).
The reason I ask is if you look at the regular L200 datasheet,
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00000053.pdf, if you look at figure 23, they use a 741 op amp with the L200 to get variable current and voltage. Is this not possible to do without an external opamp? So if I wanted to do +/- 15V with variable current and variable voltage, I would need to use op amps? If I wanted a fixed current limit, say 1A, set by a single resistor, would I need the opamps? This is all going back to the original figure 21 dual supply.
Thanks a lot.
