requim- There are two numbers that more or less describe a capacitor. They can be in many units and combinations of units. The nice $16,000 Agilent LCR meter at work lets you choose, so having it read out capacitance and ESR (which is really Rs) is no problem. Actually, many cheaper meters can do that as well. Traditional bridges will typically give you capacitance and dissipation factor, but Rs and thus ESR is just a short calculation away. One simply learns to interpret dissipation factor and be done with it. Interestingly, you can also predict the high frequency Rs (ESR) from the low frequency numbers with a great deal of accuracy. Thus, any LCR meter that gives loss (Rs or ESR) tells you everything you need to know, though not always in the units you may be used to or have been told are important. Now, an ESR meter using a high frequency is very handy, and I'd take one of those over a C-only meter any time, particularly for service work where you're looking for the injured and deceased, rather than matching and measuring values. Most of this is part of that not-quite-done link I gave above.
