GoJ, it sounds like you are beginning to entertain the possibility the pilots did not screw up? I was wondering why the pilot can overcome the stabilizer at low speeds without any problem but this that changes at higher speed. I assumed it was because at a certain speed, the airflow over the highly angled elevator starts to delaminate. But now there's another potential reason to consider.
And before MCAS there was no reason to, it was beyond normal flying practice.
This is still something that should be investigated and disclosed, regardless if MCAS can or cannot put the plane here, after the changes. Whether or not it is beyond normal, it ought to be something that that pilots are aware of, methinks.
The conclusion is then we have another Angle of Attack (AoA) fault of 22 degrees, which invokes stall warning at rotation and subsequently MCAS trimming once flaps are retracted.
This is another reason why extending the flaps might have helped, although the pilots of the Jakarta flight would not have been aware of this reason. And it seems doubtful that pilots of a 737 should/could do things that are not explicitly in their training. Treating the flaps like a "takeoff/landing" thing, only, seems like it is perhaps short-sighted, IMO. Changing the lift and drag of the wings should be an inherently useful feature in other scenarios, in my mind... the mind of a non-pilot.
We now know the crew which did switch the trim switches off, the flight before JT610, did so because a third Pilot from the sister company Batik air, flying clap seat in the JT043 cockpit, could observe the cacophony of actions an AoA disagree of 22 degrees invokes.
He had a free head as he had no flight role. He was the one which proposed switching the trim switches off after having seen the usual trimming from Speed Trim after takeoff not stopping. It was also trimming in the wrong direction (Speed Trim helps the Pilot with the feel of the aircraft by trimming in the background during takeoff and initial climb, mostly trimming nose up).
This is the one documented case that was fixed in time. I have heard others state there were multiple cases where (Americian) pilots have cut the stab trim in time, but I have not seen any proof of this. I'm also skeptical because AOA sensors are supposed to be pretty reliable, and the plane has only flown for a couple of years.
Floorbydust: good find on the details on the software-side changes.
It seems to be like a "super stall" except you are in a fast dive and the elevator is ineffective?
My impression is that "super stall" is just a regular stall, but the plane does not have enough control to get out of it by just pressing forward on the stick and/or trimming. So the plane has to be shimmied side to side to rock out of the stall. Or I suppose it could fall out of it sideways, like a stunt plane, if there were enough altitude and if the plane has enough vertical rudder/yaw control to regain control without just spinning the wrong way around. So IOW, nothing like the 737 crashes. Although the aerodynamic issues of the MAX might mean it is a plane that also stalls in a super way.
