Don't expect a behavioural inductor to work as you think it should in a .ac analysis.
LTspice does an .op operating point analysis to get the DC conditions then fixes the inductor at whatever value the .op analysis + its flux equation gives:
.AC -- Perform an Small Signal AC Analysis Linearized About the DC Operating Point
The small signal(linear) AC portion of LTspice computes the AC complex node voltages as a function of frequency. First, the DC operating point of the circuit is found. Next, linearized small signal models for all of the nonlinear devices in the circuit are found for this operating point. Finally, using independent voltage and current sources as the driving signal, the resultant linearized circuit is solved in the frequency domain over the specified range of frequencies.
Behavioural instances of Sources, Resistors, Capacitors and Inductors only 'do their thing' dynamically in a .tran transient analysis.
Also the PULSE() voltage sources will use their initial value of 0V in the .op analysis so even if there weren't capacitors blocking DC through the inductors from the voltage source, you still wouldn't see any difference unless you add a true DC bias current through the inductors.
See attached sim and plot. Edit
.param Ibias 10mA to add/remove bias current.
