Author Topic: Matching KiCad schema components with stock components in PartKeepr.  (Read 360 times)
Offline HendriXML
    • KiCad-BOM-reporter
I made a repository on github a while ago. It is useful for users of both KiCad and PartKeepr.
https://github.com/HendriXML/KiCad-BOM-reporter/wiki
When prototyping this a very handy tool to know were components are located. It can even help to choose between available parts.
“I ‘d like to reincarnate as a dung beetle, ‘cause there’s nothing wrong with a shitty life, real misery comes from high expectations”
The following users thanked this post: s8548a
Offline HendriXML
Matching KiCad schema components with stock components in PartKeepr update!
« Reply #1 on: January 19, 2019, 05:24:32 am »
Today I posted some cool updates:
First the possibility of merging calculated specifications  with schematic ones.
Showed in this thread:
http://www.eevblog.com/forum/projects/lasertrigger-circuit-signals-invalid-exposure/
Second the possibility to define numerical specifications as a range.
So now it is possible to match with resistor values from 10k to 12k, with capacitors larger than 1000uF. etc.
In this way more or less of matched components will popup in the report. This helps making decisions about which component to actually use - and where to find them.
Offline HendriXML
Main features
« Reply #2 on: January 19, 2019, 10:03:29 pm »
  • Matching
    • allow coarse or fine matching, depending on how many component requirements are added in KiCad
    • having a - in the component value in KiCad shows available components of that component kind, filtered by its requirement restrictions. Use it to quickly show all your op amps for example.
    • report stock components that match a range of values
    • share specifications between components in PartKeepr categories
  • Display
    • display E-series, see at a glance how general or special values are
    • display max voltage and max current of resistors when powerrating is know.
    • display max current of zenerdiodes when powerrating is know
    • display calculated specifications besides schematic values
  • Update PartKeepr
    • update descriptions with uniformly generated ones, also showing inherited parameters
    • update part names with uniform formatting
    • import matched stock components in a PartKeepr project
    • create parts that aren't in the PartKeepr database yet.
« Last Edit: January 20, 2019, 09:57:20 pm by HendriXML »
Offline ebastler
Re: Matching KiCad schema components with stock components in PartKeepr.
« Reply #3 on: January 21, 2019, 04:31:40 am »
Maybe you should post this in the KiCAD section instead?
http://www.eevblog.com/forum/kicad/
In the "General Chat" forum, you seem to be talking to yourself...  ::)
I assume some KiCAD users will be more interested. (Can't comment myself, since I am not using KiCAD so far.)
Offline HendriXML
« Reply #4 on: January 21, 2019, 05:50:33 am »
You’re right, I reposted at http://www.eevblog.com/forum/kicad/matching-schema-components-with-partkeepr/ with some more details.
« Last Edit: January 21, 2019, 11:04:18 am by HendriXML »
