The MOV units would be in the section plugged into the socket inside the case, the rest of it is just a power switch ( double pole, but doubt it will handle switching 10a for long, might do a few cycles at full load before failing), some input filtering ( the 2 series chokes on the power lines, and a simple mains filter with a class X capacitor across the mains and a pair of class Y capacitors from the mains to the protective earth.
The MOV unit would have had the fused ( probably a thermal fuse) MOV units, arranged with 3 MOV units. 1 across the mains, and the other 2 from the phase and neutral to the protective earth line, probably with a thermal fuse on each phase wire before the MOV units to prevent fire when they start to degrade and overheat. The fault LED/neon is wired across the thermal fuses, so that it lights when they go open circuit from overheating, indicating it is time to replace the MOV unit.
