When GPS reception is mostly blocked by skyscrapers, and GSM signal is bounced many times by buildings, Google Maps still gives very bad location data, sometimes a few tens of meters away from the real location.
Tens of meters! The end of the world is nigh!
Where's that Louis Ck interview?
Ah, yes:
I didn't own a GPS until 1994. Not exactly an early adopter.
It was a Cambridge Aero Systems GPS-NAV Model 10 and was a black box about 15cm x 15cm x 10cm with an external antenna on a BNC connector. There were I think two LEDs on the box. And a great big lead/acid motorcycle battery inside the box.
You could use it just like that as a "secure flight recorder", recording your GPS position and some other parameters (raw pressure altitude, sound level (as an engine detector)) every four seconds for the last 12 hours. It was approved for glider flying tasks and records up to and including world record level.
You could sit at your PC, enter a flight you wanted to attempt, along with you name, date, aircraft registration and download it into the GPS. All digitally signed. You then attempted your flight. If you failed .. just wipe it. No need to tell anyone. But if you were successful then you could upload the flight "declaration" and GPS fixes to your PC (again, all digitally signed), put it on a floppy disk, send it to the FAI, and they would duly issue your world record. The only other thing you needed was someone to witness your landing and take the GPS out of the glider.
In addition, you could plug an instrument panel-mounted navigation display into the GPS with a serial cable and see your current position, bearing to the next waypoint, current track and speed, and a turn-left/turn-right graphical indicator.
It was a pretty cool box in 1994, for an amateur civilian sport.
