Anti-static procedure: Step one, understand what static is, -snip- edited for the quote
All of the above. Terrahertz is spot on, but short of complete.
People keep making mistakes using ESD mitigation and prevention equipment (wriststraps, bags, mats) because they don't understand the problem nor the failure mode, nor the tools and their limits.
Here is the problem, how to solve it , and what to use and how to use it.
Static electricity is not dangerous. It is just an electrical field emanating from abunch of trapped electrons. The electrons are trapped on a non-conducting surface. Meaning they can't move. Not unless you give them a pathway to move. I can have a single pin of a super expensive chip sitting one
inch from a 10 kilovolt charge.... nothing is going to happen. Not unless i create a pathway for the electrons
If you give them a pathway to move a current will flow. How much depends on the number of electrons per square millimeter were trapped (the 'voltage') and the resistivity of the pathway.
In the example above : all other pins of that chip are floating. If i create a pathway a current will flow to 'charge' the chip to the same potential. That is sufficient to destroy it. The act of balancing the charge can kill. There needs not to be a closed loop !
Components are sensistive in two ways : the isolation barriers (the non conducting pathways) used in very small structures like in integrated circuits, can't hold such high strengts field, so you blast holes in em. So, the esd diodes in integrated circuits will trip , long before the field strength has been allowedto build. (Fields don't build instantaneously , you need to move a number of electrons to build up that field. The electron speed is limited (no, it is not lightspeed. )
Second way: while the electrons are moving (current) heat is generated in the resistanceof the pathways. Since these are very tiny , if the currentis high enough you will vaporise the small structures... Causing an 'open'.... At that point the field will build and strikethrough will happen.
The combination of both happens when you destroy a circuit with a static discarge. You blast the metal open first, the field builds and you get flashover second.
So. How do we solve this problem ?
By limiting the current in case equalisarion is necessary , or better, by preventing charge buildup.
There are three kinds of materials we can use
1 conductive : these are low ohmic and used to prevent charge deltas across a surface. Since they are conductive electrons will spread very guickly across their surface so no voltage delta is possible ( voltae delta is the field strentgh between two points on that surface.). Such materials are to be used as an outward shield ! Never as an inward shield. Since they are conductive: blast a field into them and the field will blast into the connected circuit , destroying it !
2 dissipative : these conduct , but very badly. In the order of hundreds of megaohm. These materials allow charge to 'leak away' controlled.
3 antistatic : these materials will not rrelease free electrons of themselves. You can store a charge on them ! A stored charge can be released, but the material will not create a charge by itself.
Point 3 needs clarification. It has to do with friction. Take two dissimilar materials, rub em together and you can knock off free electrons. Sweep the electrons in a pile and you build a field. Have enough of em together , give em a pathway and armageddon begins.
Animal fur and an amber rod are notorious for generation static charges.
Not all combinations work and some materials do not work at all, whatever you rub against them. Those materials are antistatic.
So how do we apply correct methodology ?
You wrap a sensitive device in a dissipative blanket first. Whatever outside charge now occurs will be dispersed very controlled. But, if the charge is high enough it may still cause problems ! Remember that it takes time to disperse charge in this material, so there is a moment where you can have a substantial voltage delta . This can still be catastrophic.
So ,you wrap the dispersive material in a conducting material. If you zap the conductive material, the charge there disperses very quickly. The dissipative material is instantaneously at the same potential everywhere, and it will leak electrons slowly to equalise with whatever is stored inside.
This is how those silvery metallized bags work. The inside is dissipative, the metal film is vapor deposited. Zap it and the dissipative film is immediately equipotentially charged and will balance itself slowly with what is stored inside. The pinkish bags with black lattice are similar in nature. The black lattice is carbon and in the order of 10 kiloohm. The pink stuff is dissipative.
Now, what do you use when ? Motherboards with sharp pins , holding a battery can be provlematic in the silver bags. Poke the pins through the bag and you short the battery in the metal deposit. So there the carbon lattice is safer.
The pinkish or blue-ish bags are dissipative.
True antistatic material is seldom used and is a specialty item for those situations where absolutely no pathway is to be present.
Given the above i will now explain how stupit it is to poke components in sheets of styrofoam wrapped in aluminum foil... You should be able to figure it out if you followed my explanation so far. Think about it and then read on to verify you understand it.
Styrofoam is notorious as a charge storage. You wrap this in a very conductive material. So you will balance the charge across the styrofoam. Poke in a chip and you fry the first pin that makes contact with the aluminum foil. Because all the stored energy now has a low conductive pathway (metallic) into the chip. In essence : the aluminum foil prevents a charge delt aon the styrofoam ... You are in essence protecting the styrofoam. Not the chip....
So the next time you go to your favorite shop and see chips poked i. Aluminum foil On top of styrofoam , laying in the little plastic drawers in metal racks ( those drawers build charge like hell everytime you open and close them)
: slowly back out of the room and while passing the threshold of the door tell the shopkeeper to read EEVblog and point him to this article.
Now, on the whole thing about grounding. There is really no need for that. As long as you do not create a low ohm pathway to equalise a field no harm will be done.
I can have a superexpensive chip in my pocket, don my chainmail labjacket and let the teslacoils zap away at me. That chip will have no damage. Why ? Because it and myself are both at a million volts. There is no voltage delta between me and the chip, no charge can move. Nothing happens. We (me and the chip) both are lifted simultaneously to a million volts.
So, on a bench : simply equalise yourself first to the antistatic bag by touching it , wait a few seconds, then grab the board. I can do this inside my cage at a million volts above ground. No problem.
So why do we tie all our equipment, bench mats to the power grid ground then ? Well.. Because of the tendency of us ,meatbags, to walk on it , sit on it or otherwise be in contact with it. And us meatbags are sometimes not conductive enough , or we hold a charge if we walk on rubber shoes , and have a tendency to stick our appendages where they don't belong ...
Pure practicality. If i walk barefooted on my concrete garage floor i dont need to put on the wristband. I wont build a potential delta between me and the benchtop mat(that is connected to the ground, or copper rod pounded into the foundation. The concrete is moist enough to be dissipative. If i wear my rubber flipflops ... Problem... I will build charge differential.... Especially when wearing my silk shirt rubbing abains the faux-leather coating of my otherwise non-conductive chair.
But since her in california i always wear short sleeved shirts and my arms touch the bench mat: no problem. I am dissipating my charge.
So it all depends. Think about what you are doing , where charges can build, and how you make sure there is only a dissipative pathway possible to balance them out.
Capice ?
