Author Topic: Motor Encoder  (Read 3287 times)
Offline SuperMiguelTopic starter
Motor Encoder
« on: July 16, 2011, 09:16:12 pm »
What are motor Encoder for? whats the function of it?
Offline Sionyn
Re: Motor Encoder
« Reply #1 on: July 16, 2011, 10:33:29 pm »
ah that a rotary encoder
dc motor i take it
http://en.wikipedia.org/wiki/Rotary_encoder
eecs guy
Offline Lance
  • Resistance if futile if R<1Ohm
Re: Motor Encoder
« Reply #2 on: July 16, 2011, 11:06:55 pm »
That's pretty much it. They're used for tracking the rotation of a motor.
#include "main.h"
//#include <killallhumans.h>
Re: Motor Encoder
« Reply #3 on: July 16, 2011, 11:16:53 pm »
why would u want to track it?
Offline ndictu
  • Country: sk
Re: Motor Encoder
« Reply #4 on: July 16, 2011, 11:20:49 pm »
You have a motor driving your robot and you want to go 1 meter forwards and then turn 45 degrees. You need some kind of feedback because the actual time you need to keep motors on will change based on battery level, weight, surface etc.
Re: Motor Encoder
« Reply #5 on: July 17, 2011, 12:20:11 am »
gotcha
Offline tecman
Re: Motor Encoder
« Reply #6 on: July 17, 2011, 12:49:12 am »
Encoders are used  for measuring the angle (aka distance) on motors, but on certain types of brushless AC motors, they are used as well to control commutation.  Adding an encoder to a vector drive can improve low speed operation and decrease coging.  AC servo motors (permanent magnet types) also use encoders for precision movements and commutation.
paul
Offline nyo
Re: Motor Encoder
« Reply #7 on: July 17, 2011, 09:04:09 pm »
Correct me if I'm wrong, but the simplest data it can give you is rpm
« Last Edit: July 17, 2011, 09:35:07 pm by nyo »
Felipe
Offline bilko
Re: Motor Encoder
« Reply #8 on: July 17, 2011, 09:20:31 pm »
Usually, you can get position, direction, speed.
A pc mouse (with roller ball) has two built in to control the cursor
Online Mechatrommer
  • Country: my
  • reassessing directives...
Re: Motor Encoder
« Reply #9 on: July 17, 2011, 10:58:00 pm »
absolute encoder is much more expensive than relative encoder, so i never work with absolute type. relative encoder you can use quadrature (binary encoding) or incremental, from there you can postprocess the parameters for rotation (relative to previous position/parameters) such as direction, angle, rate of change (speed or acceleration).
