Author Topic: My first (kinda) Project!  (Read 1798 times)
Offline Joshua
« on: June 13, 2011, 12:51:35 pm »
Alright, so I've been playing with electronics for more than a couple of months, but just built stuff on a breadboard and took it down, and built something else, took it down, repeat...    I've been trying to learn about this stuff so that explains my lack of tangible output.
Anyway, so I'm trying to become more experienced with arduino so I can do some really cool things, and I was sick of having my Uno board next to my breadboard with a bundle of wires connecting the two, so I decided to built my own usb-serial adapter based on the FTDI FT232RL. So I ordered the parts and built one according to sparkfun's schematic. The main difference is that, on their's, they had a solder jumper to select between 5V and 3.3V. I didn't like that, so I put a small switch in from my junk box.
This is my first perf-board layout so go easy on me ;)    Well actually I would prefer that you tell me what I did wrong so I can improve next time. (I.E. constructive criticism requested. )
Here are the pictures...
You probably noticed that I raised the SSOP breakout board up off the perf board. This is so I could route wires underneath for a cleaner layout.
I have seen alot of people's perfboards, and the solder bridges underneath. I always thought they just made the connection across pads with just the solder. I discovered very quickly that this wasn't the case, and that you actually bend the leads over and then solder.
Of course, It didn't work at first.  :-[  I then discovered, while troubleshooting, that I had forgot to connect the USB D- and D+ lines to the FT232. I fixed that with the two red wires, that don't look as nice as the others. That kind of irritated me because I like stuff to look nice. It works now though! I just got done programming my first arduino program with it. YAY!
Anyway, tell me what you think!
Joshua
Offline dimlow
  • Likes to be thought of as
    • Dimlow Ponders
Re: My first (kinda) Project!
« Reply #1 on: June 13, 2011, 04:21:18 pm »
Good effort, but would suggest you buy some flux, will make soldering much easier and it will look neater, just how you like it.
Offline Joshua
« Reply #2 on: June 14, 2011, 02:10:29 pm »
Well I have a flux 'pen'. The kind where you depress the pen and it comes out like a sharpie. I guess I don't know how or when to use it. Is there any information around?
Offline dimlow
    • Dimlow Ponders
« Reply #3 on: June 14, 2011, 03:43:24 pm »
The SSOP looks a little dry and could have done with the use of the flux pen, the other joints look fine.
Offline stl
  • Country: pt
« Reply #4 on: June 14, 2011, 08:48:07 pm »
I know for a fact that soldering on this boards isn't easy, to make it look good takes forever... For a first project I think it's fine, next project consider using a different type of prototype board.
Offline hannobisschoff
  • I get high on solder fumes.
« Reply #5 on: June 14, 2011, 11:01:44 pm »
LOL, in the days before Internet, young aspiring hobbyists would've had to struggle it out.
