Author Topic: Server Error Reports  (Read 30151 times)
Offline gnif
Re: Server Error Reports
« Reply #150 on: July 11, 2018, 01:30:35 pm »
Thanks, I will look into it shortly, likely someone posted an image again that is dimensionally crazy large.
HostFission - Full Server Monitoring and Management Solutions.
https://hostfission.com/
https://twitter.com/HostFission
I volunteer my time to manage this server, if you would like to support this work I have a patreon here:
https://www.patreon.com/gnif
Offline gnif
« Reply #151 on: July 11, 2018, 02:33:09 pm »
gnif, a page that just won't load or any of the posts in it.  :-//
http://www.eevblog.com/forum/testgear/siglent-technical-support-join-in-eevblog/msg1663322/#new
That's page 43. The first page in the thread and others load just fine. I can see who's posted in the Test Equipment board and then check their posts to view it and then Reply from within that member posts page.
Seen this problem for a couple of hours at least now so ~midday Sydney time onwards.
TIA
This has been fixed (image removed), a Microsoft Bitmap was uploaded to the forum with a .png extension. SMF yet again crashed out due to it's inability to check mime types...  |O
« Reply #152 on: July 16, 2018, 02:46:22 pm »
Hi gnif
Dunno if you can see it but the forum and EEVblog main page have been painfully slow to load and work with for the last few hours......like  :=\
All the other sites I'm using, no problem, quick as a flash !
Avid Rabid Hobbyist
Offline Neilm
« Reply #153 on: July 17, 2018, 04:55:59 am »
It is loading fine for me at the moment (7:55 BST)
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Offline gnif
« Reply #154 on: July 18, 2018, 12:27:00 pm »
Logs over the last week show now issues with the hosting or slow load times, and my manual spot checks have not turned up any problems.
I find it amusing though, people now really notice if it's slow... when I started helping dave out, it was normal to be slow, and people only complained if it was down.
« Last Edit: July 18, 2018, 12:29:05 pm by gnif »
Offline gnif
« Reply #155 on: August 10, 2018, 11:26:43 pm »
The short outage that just occurred was due to a connectivity failure at the data center.  EEVBlog and several other clients that host at the same data center were offline for this period. Nothing to be concerned about :)
Offline billrabinowitz
« Reply #156 on: January 07, 2019, 03:40:44 am »
keep getting an error message when I try to post a question
Offline gnif
« Reply #157 on: January 07, 2019, 04:15:34 am »
Not much I can do if you don't report what the error message is.
Offline Towger
  • Country: ie
« Reply #158 on: January 12, 2019, 08:38:00 pm »
Hi gnif,
When using Tapatalk, for the last few weeks links to photos hosted on the form are appearing as broken links.
It appears to correspond to this Tapatalk issue: https://www.tapatalk.com/groups/tapatalksupport/photos-problem-t40891.html
Which they eventually think is caused by "We find the domain of your forum registered in Tapatalk is HTTP protocol. But the attachments were uploaded to the HTTPS domain."
We have been https for some time now, so this may be a red herring or has the hosting of attached files been recently changed on the server?
Thanks,
Towger.
