Wavetek used a lot of 2N3866A and 2N5160 transistors in their function and pulse generator outputs. These were from Motorola's RF line and were optimized for VHF. I believe they had multiple ballasted emitters. I was able to get a few of each last summer from Digikey. I think Central still makes them. I have a bunch of 2N4427s from a project that developed a 33 channel laser diode array driver. Something like a 2N2219 was too slow.
HP used those or 2N5943 and 2N5583 which have an even higher FT.
Does anyone know if Maxtek is still around? We had them package a number of our ASICs in a hybrid for us in the early 2000's. I believe the fellow that ran it (Jeff?) also designed/worked on the 453 scope in the 60's. When he toured me around the facility, I said that when I was younger I had thought that Tek would be a company I'd like to work for.
xaxaxa: is there a P-channel complement to the RQA0009? If so, then an output stage for a 50 MHz function gen might be an application.
Cheers,
