True, but with low gain transistors and leaky diodes it will work at low frequency, as DTL is terrible as to logic levels. Slap a diode or two in series with the base to increase forward voltage drop and it will operate. Not elegant, but there were some old designs that relied on low gain in the transistors, and as they were so expensive the designers used a lot of diodes instead. You might need to tweak resistor values depending on location and transistor gain, but those were done. remember this is slow, very poorly defined logic, more analogue than digital.
