What about bearing checks, motor coolant, brake pads, brake fluid, wiper blades and wiper fluid, AC pressure checks, exc?
Oh, and apparently the Tesla S does require transmission oil.
On the Bolt, the maintenance schedule is attached. The schedule is for routine maintenance. Things like odd noises and brake problems are outside the schedule. Considering the dynamic braking, both automatic and manual from the steering wheel mounted paddle switch, I suspect brake life should be pretty good.
The section on Batteries (page 2) is laughable - it reads like it was a copy and paste from a regular auto.
For scheduled maintenance, you will note that tire rotation is every 7,500 miles and environmental air filter replacement is every 15,000 miles. The first important scheduled maintenance is at 150,000 miles and consists of a coolant change. At the end of the 3 year term, we might be ready for the first environmental air filter replacement. We won't be anywhere near 150,000 miles!
https://my.chevrolet.com/content/dam/gmownercenter/gmna/dynamic/manuals/2017/Chevrolet/BOLT%20EV/Maintenance%20Schedule.pdfI haven't checked the tires to see if they are of different diameters, front to rear, as they are on the Spark EV. Wouldn't that be a hoot? I'm not a big believer in tire rotation in any event. I usually move the fronts to the rear and replace the fronts - when it's time. I would far rather lose a rear tire than a front, especially on a front wheel drive car.
ETA: This maintenance schedule must be a nightmare for dealers. They make most of their profit in the Service Department.
