Author Topic: Probably not the most cost effective way of getting components for projects  (Read 1362 times)
Offline Red SquirrelTopic starter
Someone did an oopsies there.  Not only did they try to reflow the solder but looks like the components flowed to the table.  :-DD
The following users thanked this post: Mr. Scram
Offline TerraHertz
    • It's not really a Blog
Even the hinge fell off. That board is unhinged.
« Last Edit: January 13, 2018, 11:03:40 pm by TerraHertz »
Offline GreyWoolfe
  • NW0LF
I lost mine years ago. |O
Offline amyk
Looks like most of the other BGAs and SMDs stayed, but the main GPU along with a bunch of TH parts came off. I'd expect TH parts to be less likely to drop off, but I guess there's a size/weight/pins ratio difference?
Offline janekm
Yes indeed. It's fairly common practice to put PCBs through reflow a second time with lower-weight components flipped to the bottom while soldering the top-mounted components. Works fine for light components like decoupling capacitors (hence why you will often see boards with only light-weight components on the back).
