Author Topic: Pspice: Convergence problem  (Read 15038 times)
Offline s.mosfetTopic starter
« on: October 03, 2010, 08:33:45 am »
i've problems to simulate this circuit in orcad pspice:
it says:
ERROR -- Convergence problem in transient analysis at Time = 289.3E-06
Time step = 196.1E-15, minimum allowable step size = 1.000E-12
These supply currents failed to converge:
I(X_U3.xinstlm338t.VV38) = -58.24pA \ -55.71pA
what's happen?
thanks, bye
Offline TheWelly888
Re: Pspice: Convergence problem
« Reply #1 on: October 03, 2010, 11:07:25 am »
The AC sources appear to be both in phase.
Set them to be 180 degrees out of phase of each other.
You can do anything with the right attitude and a hammer.
Offline Zero999
  • 0999
« Reply #2 on: October 03, 2010, 11:40:05 am »
It won't work with the AC sources 180o out of phase. The AC sources are connected in series with each other with the 0V connected to the tap.
The circuit is correct as it is, although I'd question the series resistance and filter capacitor values.
alm
  • Guest
« Reply #3 on: October 03, 2010, 12:01:57 pm »
Maybe the LM337 dislikes the (ideal?) C16 at its output with zero ESR?
Offline Time
« Reply #4 on: October 03, 2010, 03:40:37 pm »
Make your time step larger
-Time
Offline TheWelly888
« Reply #5 on: October 06, 2010, 07:39:19 pm »
Might it be a little bit quicker to breadboard the design?  ;)
