As far as I know, power grid systems should be designed to survive and serve power even in extreme weathers, aren't they?
Depends on where you are.
Here in Switzerland, the power grid is rock solid. In the past 7 years living here, I've experienced one single power outage. Power here is nearly universally buried underground, in well-maintained conduit. It's rare to see visible cabling here.
In the US, on the other hand, I had my desktop computer and all the network gear on a UPS, because the power would go out a few times a year. The reason is that the US has nearly all above-ground power. What happens then is that ice can build up on lines and cause them to snap, but even more commonly, trees and branches fall and break the lines. (That's why hurricanes cause so many power outages.)
According to this article just doing this in North Carolina would cost $41 billion and take 25 years.
The thing about infrastructure is that it simply doesn't make financial or logistical sense to try to acheive 100% service during events beyond a certain severity level.
These articles are a fraud. No sane country puts all power line underground.
Switzerland has most power lines underground. I can't find national figures, but one of the power companies (which covers a mix of urban to rural) says it's 92% underground for low-tension, 60% for medium-tension, and 13% for high-tension lines.
There's a lot of discussion here of moving even more of the medium and high-tension lines underground, because people don't want the unsightly overhead lines.
There is a certain size, where you dont need to put it underground, as the cable is thick enought to handle any weather condition. And 95% of the power will go thrugh 10% of the cables. Just put the big cables into protected enviroment, if a block of flats loses power that is a minor issue.
Losing power statewise is a huge issue. Basically life stops, economy stops, losses are in the billions.
The problem in USA is that it's not the big distribution lines that break. In a typical hurricane or snowstorm, what happens is that thousands of small last-mile lines get snapped by fallen branches. So yeah, each one of those might only affect 10 buildings, but when you have 10,000 such breaks in a single city, it's easy to end up with hundreds of thousands of people in the dark. And because many American homes have only electric heat, this becomes a major public safety issue in snowstorms. Unfortunately, every such big storm, a few elderly people die because their heat went out and they literally die of hypothermia.
BTW I dont see poeple from Russia or Canada complaining about the snow. Surely there is more there...
Those places expect lots of snow so they are set up for it. The reason huge snowstorms like this cripple so much of the US is that they are areas that rarely get very much snow. This means they don't have enough snow removal equipment and supplies to deal with it, locals don't know how to drive in it so they crash their cars (causing even more problems), and the infrastructure and housing aren't designed for it. The parts of the US that do get tons of snow every year (think Minnesota or Colorado) have no trouble with it because they are prepared for it.
