Author Topic: Recommendations for a company i can pay to make & crimp cables in lots of 50.  (Read 468 times)
Offline Psi
So i'm looking for a company i can use to order pre-crimped cables.
Basically, what i'm looking for is 50 sets of
- 12x 24awg wires
- 1.5 meters(5 feet)
- Colors i specify
- Cut wire at one end, and a crimped connector on the other end.
The connector is just the standard 24p ATX psu connector, so nothing very specialized.
Maybe ~$4 per cable assembly cost would be reasonable.
Does anyone have any recommendations ?
I've been doing it myself up to now, but it's just time consuming and you get a sore hand after crimping that many wires. So am looking to contract it out.
« Last Edit: October 22, 2017, 03:56:12 pm by Psi »
Online Monkeh
http://dirtypcbs.com/store/cables perhaps. I've not used them for cables, and that assembly would be $5.61 each in 100 quantity..
Offline Rerouter
I have no idea on the costings, bit it seems there are plenty of companies in NZ,
The search term your after is "cable assemblies"
You can expect to pay for:
The connectors
The terminals
The wire per meter
And the setup and tooling costs.
For a batch of 50, the last 2 will be the killer, considering the other 3 likely already put you close to $3 per loom.
Offline pilleya
I've done two orders with Dirty Cables( in total 1400 cables of 6 different types), I've had them do 20 and 22AWG with JST XH, PH and dupont connectors. They do a good job and a pretty quick. No complaints.
Offline Psi
Thanks for all the ideas.
im flexible on the price so will check them all out.
