I have to say on that specific bike, i would have no chance of making the 10 meters without many hundreds of attempts, but in something more similar to my current mountain bike, i could maybe chance it in my first 10 attempts,
the swept back handle bars and set forward front wheel makes the balance more heavily influenced by the front wheel, meaning you have to steer, it would not be easy to rely on no-handed balancing, and i strongly suspect that design was picked for that fact, essentially an op amp circuit with too much gain,
as the steering axis gets closer to vertical the lean influences a larger turn, so a conventional mountain bike design would allow the rider after the initial push off to rely on standard balance with some difficulty,
not saying its an easy task, just the bike was probably chosen deliberately to remove the option of relying on body lean balance,
