If the Sweep is set to the Same Start and Stop frequency, the output should be CW at a single frequency. However, when I tried this while listening to my 2M SSB receiver (IC706MKIIG) the Tracking Generator was definitely sweeping between two 'tones' about 100 Hz apart. This sounds very much like FSK or RTTY tones with 100Hz shift or so. The Start Frequency listed is 144.19995 and Stop Frequency is 144.20005 as indicated by Olsenn. The Sweep Rate will, of course, affect whether this is heard as distinct tones or swept tones.
However, when I pressed the 'Zero Span' button, I got a nice, clean single frequency. Thus the unit should be useable as a signal source for various purposes.
I did not check how much leakage might be present coming from the unit radiated through its plastic case. There is a significant cast aluminum shield inside the unit to prevent this, however, and my roof top antenna heard nothing from the DSA815-TG until I placed a Quarter Wavelength whip antenna on the Tracking Generator output. At that point the roof top antenna provided an S9+35dB signal with the TG set to -20dBm and with a Mini-Circuits 10dB attenuator pad between the TG Output and the Whip.
By the way, when I disconnect the whip antenna and place a half-inch long piece of wire into the output side of the Mini-Circuits 10dB attenuator, the signal to my roof mounted antenna provides only an S-3 signal (with the IC706 Rx Preamp "On") thus I would think that reasonable control of levels should be possible using an external Step Attenuator.
In the 'Zero Span' mode the step attenuator can be placed between the TG Output (or in my case the 10dB pad output on the TG Output) then it can be connected to the DSA815-TG analyzer Input to check the conducted signal level.
Since you can adjust the BW/Det to 100Hz, you should be able to confirm levels down to where the internal leakage between the TG and SA input becomes the primary signal factor rather than noise. This is about -102dBm on my particular unit when the TG is 'On' but only -125dBm or so on noise peaks when the TG is 'Off'. Also note that you will probably see 'beat notes' between the input signal connected to the SA and the internal leakage signal. These will be peaking about 6dB above the internal leakage level alone.
Bottom Line: You can provide an accurate and stable signal source using the DSA815-TG Tracking Generator output.
OK, that was the 2nd from Bottom Line. See
https://www.youtube.com/jimeagle1 for an example of narrow Xtal filter sweeping.
