alternativly you could abuse a charge controller, and just run the computer direcly off the panels and a large capacitor, when the voltage exceeds a level charge controller snaps on, and computer can power up, when it gets too low, you can make something to shut it down early, e.g. one shot comparitor, and just have the capacitors serve to smooth out things like planes and etc,
or if using one of those wide input supplies, you could probably run straight off the panels, and use a similar one shot comparitor thing to turn it on and off,
just thoughts that i myself have motioned through in the past
