Author Topic: Show your favorite and most used benchtop PSU  (Read 201925 times)
Offline Fortran
Re: Show your favorite and most used benchtop PSU
« Reply #400 on: November 07, 2016, 08:46:22 am »
Put one of those electric locks on his door.
If you slip with the probe he can't get out, giving you a few minutes to escape.  ^-^
Offline BravoV
« Reply #401 on: November 08, 2016, 12:40:19 pm »
BravoV: Be prepared for a hefty price-tag. :)
The aluminium ones are crazy expensive, and the outlets for them isn't all too cheap either.
I think my setup landed on near 500€ total.
Damn, how much that aluminium bar alone ? I really love the design that it has two separated rails, one for the DIN stuffs, and the one at the bottom for the cables.  :-+
I guess I will have to improvise using plain multiboard wood planks + DIN rail and elbow grease eh ?
Online blueskull
  • Country: cn
  • Power Electronics Guy
« Reply #402 on: November 08, 2016, 12:44:41 pm »
Mine is a zUP2010, 20V 10A PSU with serial port networking possibility. My only PSU right now.
I simply use it as a 5V/12V PSU as all of my boards have voltage regulators on board, so all they need is a single external input.
Offline Fortran
« Reply #403 on: November 08, 2016, 07:52:24 pm »
The single rail ones are about 100€ per 2.5m lengths.
Dual rails are about 150-180€.
You can probably find cheaper ones, but I'm guessing you'd need to cough up at least 100.
Online lmester
    • My page
« Reply #404 on: December 08, 2016, 02:32:55 am »
I got some used transformers for free and decided to make a dual adjustable PSU. It started with a pair of the cheap PS kit boards available online. Quite a lot of mods were needed to make them work properly. Several components that came with the board were under rated.  rectifier diodes, pass transistor and shunt were overloaded. Op amps above rated voltage.
 I don't like noisy fans. I added a PIC based temperature controller for the fan.  Also, the transformers have multiple primary taps. I switch them to a higher voltage primary tap when low PS output voltage is selected. This drops the secondary voltage. In commercial PSU's this is done on the secondary side. Cuts power dissipation and keeps the fan off as much as possible.
 This is made mostly from parts that I had on hand. It still cost me about $50. Most of that for the panel meters, 10 turn pots and some nice knobs.
 Unless you have the expensive parts on hand, it's going to be cheaper just to buy one. Transformers alone will probably get you close to the price of a chinese power supply.
The following users thanked this post: BillyD
Online Vgkid
« Reply #405 on: December 08, 2016, 09:24:02 am »
Nice job on the power supply. Is that a HP5335 besides it.
What is the large black box?
Online lmester
    • My page
« Reply #406 on: December 08, 2016, 01:54:27 pm »
I may add a preset voltage switch to the power supply. I often use 3.3V and 5V.  Quicker than twirling knobs.
Yes, A HP5335A to the left. The black box is a wavetek 178 waveform synthesizer. Finished repairs and calibration on it a week or so ago. Now I need to find a place for it.
Here is a post with some pics of it: http://www.eevblog.com/forum/testgear/repairing-a-free-wavetek-178-waveform-synthesizer/msg1068993/#msg1068993
 I should see if there is a thread on here for "Show us your favorite huge heavy boat anchor instrument".  The power supply is nearly as heavy as the wavetek. Linear power supplies are quiet (low noise). I'm very noisy (Groaning & grunting) when I need to lift it   :)
Online djos
« Reply #407 on: December 12, 2016, 12:19:01 pm »
Here's my Homebrew PoS made from a PC power supply:
Edit: Argh picture trouble
Had some brain fade originally and had to move the ground terminal.
I do intend to build a better one at some point which has fully adjustable current & voltage with a purty digital display.
« Last Edit: December 12, 2016, 12:35:49 pm by djos »
The impossible often has a kind of integrity which the merely improbable lacks.
Visit my Tindie store for Tandy 1000 Adapters for EX, HX, SX, SL, TX & TL etc
Offline nanofrog
« Reply #408 on: December 12, 2016, 02:49:20 pm »
Or better yet, a quality used PSU from eBay.  ;D
Granted, this is far more of a challenge outside of the US, but it's not impossible based on what I've seen.
Offline BFX
  • Country: sk
« Reply #409 on: January 19, 2017, 09:19:53 am »
Also second HP 6632B upgraded to front terminals :)
Is little pity that I haven't original HP banana terminals but it's enough.
Finally I found good and looks like original terminals for my HPs ;)
Not this crappy Chinese from ebay:)
http://www.tme.eu/en/katalog/#search=BS-244MN&cleanParameters=1
Offline mmagin
« Reply #410 on: January 19, 2017, 11:01:01 am »
I never liked that 'black for ground, red for everything else' on that era of HP supplies.  On the supply I had to repair I just replaced all three with some good pomona binding posts, in red, black, and green.
Offline rrinker
« Reply #411 on: January 19, 2017, 01:09:22 pm »
 I guess they were past that by the 3610 days? My HP branded 3610 has red, black, and green for the earth. Unless a prior owner changed them, but they look the same age as the rest of the case.
Offline rdl
« Reply #412 on: January 19, 2017, 05:33:22 pm »
It was a change made during production. It happened sometime before the name change from Hewlett Packard to Agilent. There were other cosmetic changes made as you can see. You can find HP branded ones with the three color binding posts and the lighter color scheme, but they're not all that common.
Offline rrinker
« Reply #413 on: January 20, 2017, 01:03:34 pm »
 Actually, mine IS the lighter color like the Agilent one, but with an HP brand. I'll have to nab a picture. The spacing of the model number and specification line is in between those two - the "0-8V" part starts on the middle of my display, not over by the Amps label like the HP one and not so far to the left as the Agilent one.
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #414 on: January 21, 2017, 01:34:08 am »
This is probably my most used PSU at the time. It is a Harrison Laboratories 6263A.
0-18 volts
0-10 amps.
Made in the early 60's and still works like a charm.
« Last Edit: January 21, 2017, 01:36:06 am by Radio Tech »
Offline rdl
« Reply #415 on: January 21, 2017, 02:28:21 pm »
I prefer the later styling as seen on Agilent 3610 (and other) power supplies but for some reason want one with the Hewlett Packard name on it. I check ebay off and on, but haven't found a good one at the right price. It's possible they only made them that way for one model year.
Offline bitseeker
« Reply #416 on: January 21, 2017, 05:36:46 pm »
Yes! Those look like the right ones, in the newer-generation light gray.
Upon closer inspection of the zoomed-in image on TME's site, there are subtle differences from the genuine ones, but it's very close. Good find.
I wonder who makes them. The only other place I could find them is Amazon France.
« Last Edit: January 21, 2017, 06:18:20 pm by bitseeker »
Life is better under the TEA. ♪♩♫ Under the TEA. ♩♫
Offline rdl
« Reply #417 on: January 22, 2017, 03:39:52 am »
You can find the "gray with colored trim rings" type binding posts on ebay. They are hard to filter because there doesn't seem to be a standard way of describing them. I have bought from a couple of different sellers and the items received appear to be identical. The quality is fine. The metal post is not cross-drilled. The gray color I received is only close*. The lightness is similar to the Agilent, but is of a slightly browner shade, more like the HP color. If you are really picky about the color match, you would probably want to buy a matched set from Keysight. The last time I checked was about 2 years ago, and the cost was nearly $50 for a set of three.
* point being, you are not likely to get a perfect match as the color probably varies a lot from batch to batch.
« Last Edit: January 22, 2017, 03:42:01 am by rdl »
Offline bitseeker
« Reply #418 on: January 22, 2017, 08:34:49 am »
The ones on eBay that aren't cross-drilled have a very large, donut-like colored ring, quite different from the thinner, hard-edged HP one. However, it would be the next in line for similarity after the TME ones. So far, TME has the best reproduction as far as ring color & size, fluting on the post, and coving on the base.
In the past, I too saw the binding posts for sale on Keysight's Find a Part. However, when I checked last night they were no longer listed, not even as NFTS. :-//
« Reply #419 on: January 27, 2017, 06:55:19 am »
here are two of my PSU:
- a Rohde & Schwarz NGB 70 / 5 --- 0 ... 70V and 0 ... 5A
- from the famous german electronic magazine elrad a dual power supply --- 0 ... +50V and 2,5A & 0 ... -50V and 2,5A
  elrad November 1985
  Schematics can be found here: https://www.mikrocontroller.net/topic/183517
  The PCB was designed by myself last year, because my first attempt was really ugly  ;D (ok, this was back in 1989)
Offline bitseeker
« Reply #420 on: January 27, 2017, 12:20:25 pm »
That Elrad is mighty tidy inside. Nice job!
Offline joetorelli
« Reply #421 on: February 04, 2017, 11:45:52 am »
Here is a Power Supply I use for my Arduino Projects.
It is a 24v 5a MeanWell and two POWER SUPPLY MODULE M2L8 from ebay.
I stuffed it into an old case. Total cost was under $70.
Fits perfectly under my Fluke 45!
Offline JustSquareEnough
    • David Harms
« Reply #422 on: February 04, 2017, 01:47:49 pm »
nice job on this.  i do agree on your statement though its definitely not cheaper to build I could have bought at least one used HP off ebay by now with what Ive spent on parts for my PSU.  but I'm building it as a project to learn so from that aspect I think its worth it I am learning a lot.
--David
hobbyist of electronics, woodworking, rocketry and other cool stuff. www.davidharms.me
Offline rrinker
« Reply #423 on: February 04, 2017, 02:33:43 pm »
 Hmm, now that I should duplicate - since I too have a Fluke 45 I could slide a power supply under.
Offline boffin
« Reply #424 on: March 06, 2017, 01:46:03 pm »
A radio shack 12v 'Battery Eliminator' with a chinese CV/CC module in it.  Hard to end up with a smaller package on your desktop and still have CV/CC, although I doubt that without better cooling its ability to provide more than about an amp.
Boffin at play https://snafu.ca/
