Author Topic: SMT passive worldwide shortage  (Read 8197 times)
Offline mbless
Re: SMT passive worldwide shortage
« Reply #25 on: July 13, 2018, 02:33:23 am »
We had shortages of 0.1uF, 16V, X7R, 0603 MLCC. You know, the ones that you sprinkle on a board like salt and pepper.
Unless these are in timing circuits, you can often replace them with 0.12uF, 0.15uF, 0.18uF or 0.22uF caps.
Which would still require all of the validation they want to avoid...
Offline AlfBaz
« Reply #26 on: July 13, 2018, 02:35:35 am »
Seems to be happening with resistors as well
0603, 1%, 1/4W, 1k, not a problem right?
Mouser list 5 manufacturers, they're out of stock for 4 of them with varying volumes on order. They have just over 10 thousand in stock for Vishay (which will disappear if someone buys 2 reels) and then it's a 76 week wait from vishay
If ordering parts wasn't tedious enough |O
Offline schmitt triggerTopic starter
  • Country: mx
« Reply #27 on: July 13, 2018, 01:13:44 pm »
I agree that certain timing/filtering/EMI applications do require a precise capacitance value.
But the 0.1uF cap, when used as a generic Vdd decoupling cap, is not a magic value.....
In addition, going from 16 to 25 volt means that the capacitance reduction due to DC bias will be minimized.
However my experience has been that many -but not all, supply quality engineers do not really have a profound grasp of electronic circuits and components. And it is also true that many times the trivial changes are the ones which cause the largest headaches.
So...they play it safe and request the full validation route. The onus is in the supplier to prove that the requested change won't have problems.
Offline tszaboo
« Reply #28 on: July 13, 2018, 03:01:29 pm »
Please all remember this once and for all, it doesnt work this way.
The voltage rating of the capacitor has nothing to do with how it loses capacitance.
Take a look at this:
https://www.we-online.de/redexpert/#/module/13/productdata/=885012209014/V/asc/C/gte:10uF+lte:10uF/type/X7R
The 1210 10V part loses 20% at 10V, the 16V part loses 24% at 10V, the 1206 10V part loses 37% at the rated voltage.
The following users thanked this post: Ice-Tea, mbless
Offline rx8pilot
« Reply #29 on: July 13, 2018, 04:14:59 pm »
What?
6v part vs 25v part
The 6v part rolls off C value much faster with a rising voltage.....
If you are operating at 1V or so - who cares? I think the point is that in the face of a shortage, a higher voltage rated part is usually not a problem. If the original designer was allowing more than 50% rated voltage - the circuit would see an increase in capacitance. If it was designed under 50% of the rated voltage the C change based on V bias would be negligible.
Offline thm_w
  • Non-expert
« Reply #30 on: July 13, 2018, 09:14:56 pm »
Not always shortsighted. Yes, some component substitutions can easily be justified. But if you rely on certain caps to meet EMI standards in a harsh environment, and then you change the caps, then I too would want the EMI testing redone.
You are not changing the capacitance or temperature rating, if the circuit was designed appropriately, only the maximum voltage. If you look closely at the parts they may literally be the same part remarked as various voltages.
Of course if this is some ultra harsh environment it could deserve retesting, but that would be the case even from switching vendors. That's more of a reliability test than EMI though.
Offline MT
  • Country: aq
« Reply #31 on: July 14, 2018, 10:36:35 pm »
Ooh! The good ol' "spot market" days from the 90'ies is back i supose! :popcorn:
Offline ubbut
« Reply #32 on: July 16, 2018, 07:44:21 am »
It was my understanding, that the voltage rating does not influence the capacitance decrease (at least not very much). The main factor is the physical size:
https://www.maximintegrated.com/en/app-notes/index.mvp/id/5527
Offline Kjelt
« Reply #33 on: July 16, 2018, 09:56:22 am »
So how do you guys handle this in your new designs? Checking current stock is no guarantee for future stock.
At the time you are ready for production ( half year later ?) some parts might not be in stock anymore, what are you gonna say ?
Asking the logistics dept to order the parts in advance is a political nightmare in it self (against company policy?).
Offline tszaboo
« Reply #34 on: July 16, 2018, 11:14:35 am »
It shouldn't be. You should plan deliveries of products with like a year in advance. How else do you plan production? Spot buying everything, not talking to vendors, and manufacturers?
It is a political nightmare though that I need to explain this to upper management. Like they cannot just start a new product all williy nilly next week.
Offline Kjelt
« Reply #35 on: July 16, 2018, 11:21:22 am »
In my previous company there were preferred part lists and those were bought in huge quantities in advance and dynamically stocked up.
If you design in a new part you needed a very convincing story, but than indeed only after the engineering validation runs so 9 to 12 months later the components would be stocked in production quantities. If the components is from a preferred supplier the contracts were already done, even with cancellation clauses, but with a non preferred supllier it did happen we had to postpone production over 6 months due to component shortage.
Offline GreggD
« Reply #36 on: July 16, 2018, 11:27:27 am »
For 100nF (0.1uF) I only use the most common 50V parts. They are cheaper than 16V as there sold in larger qu.
The voltage rating of a X7R/X5R has little to do with capacitance reduction due to DC bias. Case size 1206 vs: 0402 has a very large effect on capacitance retention. Use larger caps.
  • Country: mx
« Reply #37 on: July 16, 2018, 03:20:28 pm »
I have asked that same question many times. However...........
Depending on how the accounting and tax structure is set up, inventories have very significant financial implications.
Don't ask me to explain them, I don't fully understand them myself.
Offline Kjelt
« Reply #38 on: July 16, 2018, 03:46:12 pm »
Yes that is true, inventory can financially be quite expensive. Writing off components that are beyond the very conservative shelf life due to moisture mostly can also be a big factor.
Not being able to produce anything for a half year costs nothing ofcourse  |O  :)
Offline MT
  • Country: aq
« Reply #39 on: July 16, 2018, 09:56:48 pm »
Back in the 90ies at that time  purchase department just bought whatever they could get hold of and called us instead and asked if such and such can be a resonable substitute, later we just got  their list and went through and X'ed whatever was OK. But it was one of those super big multinational companies they had resources. Despite their several year spaning contracts with the big manufacturers they had to go into the spot market.
« Last Edit: July 16, 2018, 09:59:38 pm by MT »
Offline tszaboo
« Reply #40 on: July 17, 2018, 03:07:26 pm »
If you order something, you dont pay it ASAP. For example, you order a million resistor for your doodad, you only pay for the resistors 60 days later. In that 60 days, you assemble the doodad, and send it to a customer, and get the money for it. From this money, you pay the resistor supplier. It is called company credit.
If you buy a large stock of components, which you dont use it right away, you need to pay it before you got payed for it. It means that the company actually has to have that money, or get it by other means, investors, bank credit, etc. It doesnt sound like a big deal, but it is. It means that a small company can do big business. If you spot buy on Farnell, not only do you pay potentially 10-100 times the price for the component, it also means, that only big companys can do small business.
Of course there is also the possibility to have a lawyer sitting on meetings with suppliers, and write contracts, that are very expensive to break. I've seen a PCBA company assemble a board with loss for years, because breaking the contract would cost more. Big players are doing this, basically when you order, you also state a penalty for late delivery is x% every week. Sometimes it is even just setup in a system like SAP, if you didnt get the parts, they get a penalty invoice with no human interaction. Of course production will see it, but that is another story.
  • Country: mx
« Reply #41 on: July 17, 2018, 06:05:41 pm »
That has happened to us.
The material arrived at our customer's dock the very last allowable day, but nevertheless on time.
However, the customer's receiving department did not scan the boxes that day......for all purposes, the material had not arrived to the stockroom and we got penalized.
The charge was disputed and later revoked, but you had to have a person spending a lot of time clearing it up.
Offline Nortek-Chris
« Reply #42 on: July 20, 2018, 08:01:42 am »
I don't see supply issues with 0402/0201.
It may be happening soon with 0402. Murata issued a bulletin a few months ago, giving notification that various value of some older series' are being discontinued and 0402 was included in one of the range listed in their EOL notice. Last time buy from them is March 2019. No Values are actually listed on the Bulletin, but I hope hope that the more popular values like 100nf continue to be produced, but i'm not holding my breath for the longer term.
https://www.ttieurope.com/content/dam/ttiinc/products/PCN/Murata/Murata-Obsolescence-PCN-032018GR-ZRA.pdf
This is also part of the problem, some key MLCC manufacturers are ramping down production of 0402, 0603, 0805 etc, in favour of 0201, which is the package size favoured by their larger customers, especially Automotive, and when you think that there can be upwards of 10k pcs of 0201 MLCC parts in an average Electric vehicle then you can see why its in their interests to discontinue the older parts and use the extra manufacturing capacity to produce the 0201.
Unfortunately, as manufacturing capacity and output of 0402, 0603 etc versions drop, it puts the pressure on the remaining manufacturers to pick up the demand, and lead time continues to increase - rinse and repeat. So I can't see any improvement happening soon.
« Last Edit: July 20, 2018, 08:05:31 am by Nortek-Chris »
Offline Kjelt
« Reply #43 on: July 20, 2018, 08:07:04 am »
What is the logic behind this?
0201 MLCC has a huge derating. The result is hardly any gain in surface space or am I missing something?
For resistors yes but for caps I don't get it.
Offline ubbut
« Reply #44 on: July 20, 2018, 08:08:02 am »
Soooo..... Any suggestions on what we could do to get hold of at least the most necessary parts?
Spent about 2 days comparing 5 distributors to find 10u 0805, 25V at reasonable prices. Mouser had some, but the next day they were gone of course.
Offline tszaboo
« Reply #45 on: July 20, 2018, 10:04:33 am »
Order in advance?
BTW you shouldn't select components based on the spot market price.
The issue I'm seeing now is that they dont have it even in prototyping quantity anymore. There are zero 0402 1uF X7R capacitors in the mayor distributors.
« Reply #46 on: July 20, 2018, 10:24:23 am »
I've worked in a purchasing capacity for an Electronics Manufacturer for over 20 years and still haven't figured it out!, in the early days I drove myself old and grey trying to work out the logic behind the component manufacturers. Back then it was Amp / Tyco (TE) connectors. I never quite worked out the fact that you could get a free plug assembly Ex-Stock but had to wait 10 weeks for the mating PCB connector. That is a bit like going into a shoe shop and buying the left shoe immediately, but having to wait 10 weeks for the right shoe to turn up  |O. These days I don't bother getting stressed over it, it is what it is.
All you can do is to act on early warnings and buy stock or schedule call off orders in advance before the price increases (The potential for the current problem was highlighted in some distributor blogs and newsletters back in 2017). If you buy in Volume then distributors like TTi or Rutronik are your best bet, and if the design allows also look at 'unknown' brands like Hitano which can often be overlooked by other volume 'brand' users. There is also a Uk based distributor called VTM  who seem to be able to offer shorter lead times on their "Tancap" brand.
I suppose it depends on which distributor you use and your relationship with them, however I find that for production volumes and despite the aforementioned EOL notice, buying Murata currently from TTi seems to yield faster delivery times although given the EOL notice, that may change soon!. Samsung seem to be the worst for lead times.
« Last Edit: July 20, 2018, 10:37:59 am by Nortek-Chris »
  • Country: mx
« Reply #47 on: July 20, 2018, 01:30:22 pm »
And, let's not forget:
Trump's trade war with China.
Adding more fuel to the fire.
Offline rx8pilot
« Reply #48 on: July 20, 2018, 06:29:03 pm »
Sadly. True.
