Hmm I must try my tests with a wider temperature range. Unfortunately this thermometer only goes to 120F, so I need to make a solid RTD circuit. Maybe I will finally do something with these peltier coolers that I have had sitting around for a year.
According to this document typically TCR is made from a 25-75 degree range. I suppose this makes sense because you are probably doing something wrong or very special if your PCB is above 75 degrees.
http://www.token.com.tw/pdf/resistor-ppm/resistor_ppm_terminology_glossary.pdf
I don't agree with that test range at all. Real world gear is often subjected to much higher and sometimes lower temperatures. A typical power amp or power supply, LCD display, Plasma TV..etc.etc. I think you'll find over 100F in many of these items. I've also found going above a certain point doesn't impact the measurement. I've tested up to 130F so far and didn't see any change in the ppm's.
On another note I just tested a thick film 180k Chinese 805 size SMD resistor, and it scored in @ 19.6 ppm over 56F to 126F. I have thousands of them, so at least I have something to build with.
Also from what I understand the higher the resistance the higher the ppm will be.
If you put a positive tempco resistor in series or parallel with a negative tempco resistor do you end up with a more stable resistance ? In theory you should. Pretty sure that's the principles of basic temperature compensation where your offsetting drift in silicon with an opposite drift.
Jeff
