In my proprietary system, I use bi-directional communication to determine the voltage/current that will be delivered. It takes all human decisions out, they just plug in and go. My design is for a specific commercial use, but the concept could work in a house.
This is also how EVs charge, J1772 and similar.
Once you've gone to this point, you might as well take it a bit further, like letting someone plug in a generator or PV panel and that, too will negotiate a voltage and current (and, obviously, a direction). This is part of what the idea of "nano grids" are about:
http://nordman.lbl.gov/docs/icdcm2015nordmanLPD.pdf. Basically, letting loads and sources work out between each other what's going to happen over a circuit.
And once you have that negotiation, it becomes interesting to put network control on all the outlets, and maybe even allow devices to work cooperatively to maximize the use of a circuit. For example, if you plug in a blow dryer and a toaster on the same circuit, they will negotiate who gets to run and who doesn't. (That was a particularly bad example, as I don't think many people make toast in the bathroom, but some might dry their hair in the kitchen.)
But my point is that intelligence is nice, but it would be semi-tragic in my mind to come up with a ubiquitous intelligent power transfer negotiation standard that did not allow for more features.
Of course, I don't see how any of this militates for either DC or AC, as it can be done either way, though arbitrary voltage conversions for AC are a bit more expense (capital and efficiency costs).
In my mind, the decision for AC or DC is not so much about "what is best" but about "winners and losers." On a DC system devices with power supplies will save a few pennies by eliminating a diode bridge and some filtering (winners). Resistive heating devices won't care (neutral). Large induction motors will require VFDs to synthesize their local AC drive (losers). Whether such a conversion looks appealing to you has a lot to do with who you are and what your main loads are. And of course, if you make stuff that would need to be replaced, you probably would be *thrilled*. If you own stuff that needed to be replaced, much less thrilling.
That said, I'm not happy with the idea of low voltage DC like 48V. Any savings you make in devices and maybe conversion efficiency will be paid back in i2c losses in the wall and/or more copper.
