Flashlights in non-emergency situations are best still battery powered for sheer lumen/watt output, such as security guards, searchlights etc.,
For emergency use, the last thing you need is something that will steal heat away from you. Even in temperate climates, protection from cold is important. The bodies first response in emergencies is to sap heat from your extremities to conserve it in your core, so charging something by holding it would take a long time, if at all. A more useful thing if you were in a bind in a terrestrial condition would be power generated from walking [ electromechanical transducer in your shoes, many such designs]. In ocean emergencies it would be solar power; combine them both for an ultimate emergency power source and back it all up with a crank generator in a MILSPEC water and shock proof case.
