I am sure it would consume more then 7W to simply produce a suitable vehicle/suit, that's your entire budget gone before launch.
In theory, you could make one that uses thermopiles (which convert temperature differences into electricity), with the self heating human on the inside (not sure of exact amount, but it is probably around 50 Watts of heat energy produced) and the near absolute zero temperature of outer space (during most of the journey).
Also, using very high efficiency techniques, the suits power consumption, should be reducible to a small amount.
I.e. the very approx 50 watts, can be used to power the suit. Some of the energy the suit uses, can also be re-converted back into electricity, and make a closed cycle thing, which uses very little or no external power.
In (hypothetical) theory, at least. (In practice the mobile satellite phone and entertainment system, will need 750 watts
EDIT:
But the suit/craft does do a lot of important/vital life support functions. Such as air-conditioning, refreshing the oxygen and removing CO2 etc. Water control/extraction/recycling. So I just hope that all the necessary functions can be performed, with little or no, extra power, being needed.
