None of you know anything about electronics. A blind monkey knows stacking the capacitors is part of a tuned circuit where if the sides are high enough, they will short out to the metal case making the entire thing radiate microwave energy at 1.21 jiggerwatts, drawing power from the stack of fux capacitors.
Seriously, I did find that comment earlier on that it looked like it was soldered by a blind monkey hilarious. I will use that on a few colleagues in jest at the appropriate time.
"You code looks like it was written by a blind monkey"
"What, did you outsource your soldering to a blind monkey?"
"A blind monkey can see I deserve a pay rise"
"A blind monkey could run this company better than you do."
Using the last one might be CLM (career limiting move)
